songmic
I got a call from my family that my JH13 Pro just arrived!
Oh boy, I can't wait to go home to listen to it!
Do post pictures and share your impressions when you get yourhandsears on them!![]()
Here are my first, honest impressions after I listened to my new JH13 Pro FreqPhase for a 1 hour. My opinions are subject to change as cable burn-in continues, or if I grow more and more used to its sound.
I should mention that I've used it with Moon Audio's Silver Dragon V1 IEM cable, and RWAK100 (AK100 modded by Red Wine Audio) as my portable setup. I'll soon try it with my main desktop rig as well, driving it with my Zana Deux SE though it may be overkill for IEM's.
First off, I was slightly disappointed by its lack of soundstage compared to my full-sized cans such as HD800 or TH900. The JH13 Pro doesn't have the pinpoint imaging capability found in my HD800 or TH900, either. I guess I can't really complain though, since that's the inherent nature of IEM design, which inserts music directly into your ear canals rather than the entire width of your auricles. As David Solomon put it in a similar way, I can't complain open-back HD800 for its inability to isolate, or closed-back TH900 for its smaller soundstage compared to that of HD800 (the TH900 still boasts the best soundstage I've heard in a closed headphone). I think I could draw a more spacious soundstage if I drive it with my ZDSE, which is known for its exceptionally deep and wide soundstage and what I primarily use for both my HD800 and TH900. Still, I don't think I will be as impressed as I'm with my HD800 or TH900, and besides, I will be using my JH13 Pro mainly outdoors. I wish I could compare it to other IEM's, but unfortunately my JH13 Pro is the very first audiophile-grade IEM I've heard.
But here comes the good part... other than imaging or soundstage, I feel the JH13 Pro is on the same league with my full-sized cans (HD800, LCD-3 and TH900) in almost all other areas. All in all, I was very impressed by how high-end the JH13 Pro sounds.
Of my trio of flagship headphones from their respective companies, the JH13 Pro's sound signature was closest to that of the HD800. The HD800 also happens to be the headphone I use most frequently of the bunch. The JH13 Pro sounds very neutral and balanced. I heard its more expensive brother JH16 Pro is more colored and darker-sounding due to its addition of 2 more bass units (whereas the JH13 Pro has 2 units each for treble, mid and bass). I am guessing the JH16 Pro would sound more like my LCD-3 or TH900, which I consider more euphonic and fun-sounding. But for neutrality, critical listening and ultimate technicality, I prefer the HD800... and the JH13 Pro fits the bill as well.
Inadvertently sharing the HD800's traits, I felt that the JH13 Pro is sometimes bright and thin sounding at times. The reviews I've read on the Internet says that the JH13 Pro still has plenty of bass (although not as much as JH16), I'm personally a basshead and I do feel that the relative lack of bass in HD800 is one of its shortcomings, which is why I'm attempting a mod to take the edge off its hot treble and add a bit of warmth to it. I feel the same way with the JH13 Pro, although I'm not aware of any mod that achieves this effect. Maybe, if I use Moon Audio's Black Dragon (copper) instead of Silver Dragon (silver) cable, the sound will become warmer, less sibilant and a bit bass-heavier?
This is all I'll say for now. Again, my opinions can change over time, so stay tuned.
I was aghast when you compared the RE-600 favorably to the JH13s last week. "Even" my non-FP JH13s are in a completely different league.the burn-in is HUGE on my JH13s. Almost 150 hours now, it sounds MUCH better than out of box. The sound stage was like 20 time smaller than hd800 in the beginning, mid was dry, and treble could not sparkle. Now it sounds like a completely different IEMs. oh man, can't believe this....
