bluishgreen
- Jan 29, 2012
Would it make sense that to me the amplifier would make no difference considering I the C421 is my first amplifier? + I just realized how softly I listen to my music as I often am teetering on the edge of imbalance with my low impedance headphones.
Or rather, it's your first external amplifier...you can always compare it to the built-in amplifiers of whatever devices/computers you currently use...
The external amp is more about sound quality than sound quantity/volume, although it serves both purposes with higher-impedance phones. However, it also isn't a silver bullet if you are unhappy with the quality of your current phones' sound (especially if they are already more than loud enough) or if your source output that you plug it into is noisy/low-quality. Except for bass boost features, ideally the amp shouldn't be changing the sound at all, other than amplifying it, so it's only going to improve things if your built-in amp is the weak link and degrading things. And even then, if you plug the external amp into that same built-in amp/output (because maybe it's your only available output) then it's just going to forward-on a louder version of what you didn't like to begin with, unless you have a line-out port or use an external DAC to bypass the built-in amp/output/soundcard.
In any case, if you are referring to the opamp and whether it matters which one you buy--I've only listened to the AD8620, but the general consensus seems to be from the main two choices: the AD8620 has a neutral-to-slightly brighter sound signature, while the OPA2227 has a neutral-to-slightly warmer sound signature. There may be other subtleties, but that's probably the most prominent aspect you'd notice, and a decent rule-of-thumb to go by. There's also a third choice, although JDSLabs seems to recommend the AD8066 specifically for higher-impedance phones, which doesn't really apply to you. So, I think I'd just go by what basic sound you are looking for in general--do you usually prefer a slightly brighter sound or a slightly warmer sound--and go with that. Keep in mind that we're talking about subtleties here, since again, the amp should generally be neutral and shouldn't be radically changing your sound, other than cleaning-up the non-neutrality that another amp left behind...
