JDS Labs C5/C5D (pg96) portable amp/amp+DAC
Jan 26, 2013 at 7:34 PM Post #31 of 3,417
How does the C421 compare to say the O2? That is the only one I have actually heard of that is built by JDS Labs.
I'm guessing this is an upgrade so should sound better than the C421 if that is infact newer than the O2?
O2 has the upper hand in clarity and power, but C421 is still a great amp, and way more portable.
What about battery time on C5 John?
Jan 26, 2013 at 7:45 PM Post #32 of 3,417
From the Facebook update:
Most customers expect at least 8 hours run-time, so 10-12 hours is common with high-end amps. This has not changed.
Jan 27, 2013 at 2:30 PM Post #34 of 3,417
No amp should sound discernibly "better than" O2. At that level of performance, the best you can expect in an A-B comparison is equal transparency.
O2 wins in maximum output power. C5 wins by a longshot in channel balance and ease of portability.
Jan 27, 2013 at 2:37 PM Post #35 of 3,417
Cheers for the reply. I was just wondering what the differences in each model were, and the sound characteristics.
Channel balance? I don't quite understand what that would mean. Better seperation? Or, left to right channels are more equal?
Jan 27, 2013 at 3:10 PM Post #36 of 3,417
Better channel balance as in it won't suffer from the channel imbalance one gets with the O2 (or most volume knob controlled amplifiers) at low levels.
Jan 27, 2013 at 3:29 PM Post #37 of 3,417
Features and specifications will be posted with the preorder announcement. We'll leave subjective reviews up to you guys.
Channel balance is the amount of error between the left and right output signals (i.e., does one side sound much louder than the other?). Any amplifier which relies on an analog potentiometer will exhibit some degree of channel imbalance at the lowest threshold of knob rotation. That imbalance can be severe until you turn the knob past the imbalanced region, usually the first 10-20% of knob rotation.
Analog potentiometers are low cost and perform well--as long as you listen at volumes above the imbalanced region. Implementing a digital volume control without degrading THD+N is a challenge. Done right, it's worth the expense.
Jan 29, 2013 at 1:05 AM Post #38 of 3,417
Does the C421 provide a significant bass boost?  Will the C5 offer a similar bass boost?
Good timing finding this thread.  If I didn't know about the C5, I might have already ordered the FiiO E12.  Now I have a tough decision coming up with Verza on the way as well.
Jan 29, 2013 at 2:31 AM Post #39 of 3,417
The C421's specs say:
Bass Boost, +8dB peak
I'm guessing the C5 is a similar bass boost too.
Jan 29, 2013 at 9:59 AM Post #41 of 3,417
Wow another creation from JDS. Gotta compete for dollars going towards the highly anticipated E12. Seriously though, I love the c421 with the 2227 opamp. I would have to see more than improved channel balance and a lever Alps control though. And I own the CMOYBB, c421, and O2. Next amp I buy will be the E12. Although I am sure this will sell well.
Jan 29, 2013 at 10:30 AM Post #44 of 3,417
I personally think 8db is too much of a bass boost. Would love to see a 2 stage implementation of say 3 and 6db. Amp is looking great.
Agreed. +8db does seem like that's a lot of boost. Most people that would buy a amp at this price point would simply buy Sony XB700s if they wanted their headphones to sound like that :)
Jan 29, 2013 at 12:25 PM Post #45 of 3,417
If that is the case, +1 for C5 vs. E12's (+3 dB).
It's all speculation at this point, that was just my guess. The CMoyBB has a +9.4 dB bass boost. :o
JDS Labs will release the official specs within the next week-ish.
