holsen
I'd like to broach (breach?) a matter concerning Atom amp that thus far i have not seen mentioned anywhere. Has anyone else experienced this?
I know these things can be perplexing, frustrating and maddening even but man it feels good when we solve them! I'm sure you've been up and down this thread - I Don't recall seeing any other report of such issue, I certainly haven't experienced it with my set up. Sounds like JDS has attempted to be thorough with you and your gear going so far as to send a 2nd unit which now exhibits the same issue. Given the fact that JDS couldn't reproduce the problem and none of us have a problem and now you've got 2 units with the same problem.... Deductive reason tells me the problem is somewhere in your audio chain. What are you using to feed your DAC? What is your DAC?
You mentioned something that's curious to me. You said "
I then discovered my main DAC can do the same thing, when used alone."
So why aren't you looking at the DAC as the problem?
Have you tried cable swapping the RCAs? DAC settings?
With all the info you supplied, I'm fairly certain the problem isn't the Atom
Not trying to be critical or *smart* here, I'm just trying to help.
