Nov 14, 2020 at 12:09 PM Post #513 of 643
Nov 14, 2020 at 12:26 PM Post #514 of 643
The first review states:
" The JDS Labs Atom is a warm and thick sounding AMP, but it doesn't choke your music, nor does it make itself too forward. "
Has anyone else called this amp warm? Every other review has called it neutral or transparent.
Yeah, that confused me, I thought that the Atom along with the 789 were the 2 affordable choices for transparency when they came out.
Nov 14, 2020 at 10:41 PM Post #515 of 643
My experience with my JDS Labs Atom is anything but warm. To me it's neutral and transparent. Maybe the reviewer is using a warm sounding headphone in the review that's why he said it sounds warm.
Nov 16, 2020 at 4:22 PM Post #516 of 643
Reading through the review again the headphones that are used are never explicitly stated. He said they can power an LCD-MX4 so maybe that's why he's calling it warm. I don't want to nitpick but but the review also states, "There's nothing that's quite like the Atom in terms of price and especially price / performance". Guess he's never heard of a magni or the liquid spark...
Nov 20, 2020 at 9:43 AM Post #517 of 643
I think I know the answer to my question, but are people able to use their Atom amp with sensitive IEMs without any noise? My current amp has a low hum (from the power supply) at low volumes, and a hiss at higher volumes. My IEMs are Westone UM Pro 50 (45Ω, 117dB@1mW).
I'm thinking of asking for an Atom stack for X-Mas this year.
Thanks, all!
Nov 22, 2020 at 7:07 PM Post #519 of 643
Thanks, all!
As much as I love my Atom, the Topping L30 has a -9db low gain option that is very helpful if you get into even more sensitive IEMs. The low gain on the Atom is 0db.
Nov 22, 2020 at 9:39 PM Post #520 of 643
Thanks for that. Is the Atom too loud with IEMs?
I doubt that I'll be getting anymore IEMs anytime soon, and I stay away from the super low impedances as a rule.
Nov 22, 2020 at 11:33 PM Post #523 of 643
Funny how they all perform similar at the top. What headphones do you use?
I have the LCD2C, AKG712, HD 6XX and Focal Elex, I find that whilst I understand that the THX 789 is definitely powerful and quite possibly my last upgrade in terms of amps, if i don't choose to go to tubes, I still find very little difference when comparing the two listening wise. Plus I haven't gotten much time to sit down and listen due to work and study, so I kinda regret upgrading tbh, as the Atom did a fine job.
Nov 22, 2020 at 11:47 PM Post #524 of 643
You mention tubes. You can set up a tube with that amp on the second input and toggle back and forth with inputs. How do you like the Elex? I ordered them from drop but read that they had build issues and cancelled.
Nov 24, 2020 at 1:29 AM Post #525 of 643
Thanks, all!
Not sure how useful this is since their specs seem a bit less sensitive than the Westones, but my Moondrop Starfields had zero audible noise at any volume level with Atom + SDAC. I was actually kind of shocked because even the Audioquest Dragonfly brings in some noise, Atom has been dead quiet with anything I throw at it.
