warbles
Thought it might be simplest to supply photo of the hindquarters of my stack. You can see i hope that i use just the stock connectors which came with the units.I was suggesting that maybe you have faulty RCA cables. You must connect the Atom DAC to the Atom AMP somehow, I'm assuming you're using RCA Cables to do that.
Anyway, let's see if we can help you figure it out. What is your audio chain? I'll describe mine so you know exactly what I mean.
PC > JRiver Media Center > Topping D50s DAC vis USB > Atom AMP via RCA
Ive got the output from Jriver to Topping DAC set to WASAPI drivers
Let's start with this and see what we come up with
- What is your source that feeds your DAC(s)
- What driver output setting do you have that source set to
- How do you connect your source to your DAC?
- How do you connect your DAC to your AMP?
My source is either Tidal.or Spotty from a laptop with the XMOS drivers installed via JDS' own website.
How would the RCAs be faulty? In what way and how would one know?
