The Sine uses dual 2.5mm connectors at the cups. Not sure what other Audeze cans uses. In theory you could put new connectors on it but the DSP is going to be tailored for the Sine's use with iOS devices, however subtle or strong the implementation is.
The cool thing is, you can download the Audeze app and configure EQ settings. The cable will memorize those settings and use them across all your iOS devices you plug it into. This is just the tip of the iceberg of what we'll see in the coming years.
Actually, the Sine use small 3.5mm connectors. Meanwhile, LCDs use 4-pin mini XLRs, and EL-8s use proprietary PCB type connectors.
You could change out the connectors since the DAC components are located on the cable, and that will increase output power.
Stay updated on PlusSound at their sponsor profile on Head-Fi.
