diamondears
- Oct 1, 2014
Well, without an oscilloscope no one will can tell.
Couldn't an expert determine that looking into the design and specs?
Bit the bullet and got Kaisertone app. Very impressed with the quality and definitely a serious step up from Onkyo HD.
Not to discredit Onkyo HD but with my Westone UM-Pro50 I can also attest to better layering, better soundstage and tighter punchier bass. Vocals are very smooth and detailed yet warm enough. Overall better definition in sound.
Very pleased. The EQ options are endless but I don't even need it playing everything flat. Using iMazing on OSX to transfer flac files to the iPhone. Too bad it doesn't allow streaming from Tidal etc. But I'm not complaining ^_^
I was going to get the KaiserTone Audioplayer but as soon as I saw how they advertise the app in the Appstore with Nickelback cover art, I immediately decided to stay with Neutron.
Does anybody know if the iPhone 6+ uses full bits when you're using it with a HP directly plugged with volume not maxed out?
In other words, does its DAC deliver full bits to the amp section withiut being affected by the amp volume?
I would guess it uses a digital volume, since their priority is space in the design.
With all the KaiserTone praise i went ahead and purchased it. The sound quality is awesome via my 6+, but i have one major issue thus far. I cannot get playlists, albums etc to automatically advance to the next track. I manually have to press the forward button. Am i missing something? Is there an option or button i need to select in order for it to do this automatically?
