Apr 22, 2016 at 12:42 PM Post #3,541 of 4,830
Apr 22, 2016 at 4:41 PM Post #3,542 of 4,830
so hopefully someone can point me in the right direction- i ordered a pair of Atlas monitors after the glowing reviews here on headfi and its been about a month and a half and i have not received the items with no response from the email address listed on the "contact us" portion of Trinity Audio's website. i know the staff aren't the type to ignore their customers so i just figured id give it one last hoorah to see if i could rectify the situation and hopefully be on my way to the slamming bass these workout puppies produce! 4045021007 I'm easier reached via mobile text or call as headfi is now blocked (thanks to yours truly :)
Apr 22, 2016 at 4:59 PM Post #3,543 of 4,830
Yes, this is highly irregular for Trinity and it sure does not take a month for their products to ship from UK to the Atlanta (based on your area code) area so I'm sure Bob will chime in soon and get to the bottom of this!
Apr 22, 2016 at 4:59 PM Post #3,544 of 4,830
A PM to Bobtrinity would be the most appropriate way to approach them I'd assume ;)
Apr 22, 2016 at 5:05 PM Post #3,545 of 4,830
Pm me your name and address and i can check for you. As all Atlas are sent express we have full tracking.
Apr 22, 2016 at 6:03 PM Post #3,546 of 4,830
davmet are tiny.  Alliance Group.
But this is getting off-topic. Bob suggested I simply use the Atlas filters with the Sabres - so I should be able to run through them all tomorrow after all.
haha yeah
Apr 23, 2016 at 7:27 AM Post #3,549 of 4,830
Posted from Sabre thread - has a lot of info about Delta 2.
To everyone waiting for these impressions - my apologies. I got hit with a computer virus a little over a week ago, and it wiped out a lot of data (last back up was three weeks ago) – including all my measurements, all my photos, and a lot of the reviews I've been working on.
As usual - the measurements are with Veritas and ARTA.  They are raw data only, and are included here more as a means of showing comparative differences than absolute measurements.  they should be reasonably accurate between 20 Hz and about 4-5 kHz.  Above 5 kHz my gear measures low.  Hopefully one day i can get it calibrated properly.
SABRE IMPRESSIONS
So if we go back time the last time I heard the Sabres – my conclusion was that they sounded pretty good, but ultimately had too much low end for my preferences (http://www.head-fi.org/t/796729/trinity-phantom-series-new-thread-worlds-first-push-pull-hybrid-iem/165#post_12333122)
I loved the mid-range and the lower treble, but I just found that bass a ltitle too much.
So what has changed?
We'll skip the comments on accessories and packaging. You guys know what comes with the Trinity line-up by now. I'm not sure what Bob is doing about the longer filters – and whether they are being included.
Sabres build is the same
Good angle on the nozzles but fit is shallow
2 pin connector - see Delta pics for better idea
If you go back to my previous post, it covers build, fit and comfort. Nothing has changed there – but I will show you the Delta V2 connectors – as I think that is what will end up on the Sabre. These are actually pretty cool. The connector sockets protrude about 2mm outside the case, and they are encased in some pretty hard plastic. It is really sturdy. The connecting plug itself then fits over the protruding housing (really firm too), connecting the pins, and giving them a double layer of protection. It's a pretty nice set-up. The cable this time is the standard high quality cable you see on all of the other Trinity line-up.  See photos of the Delta 2 further down the page.
Note small vent/port
Filter system same as Atlas
Look inside the shell
Fit is the same as last, time but this time there is zero driver flex. Fit is still shallow – but I'm getting a great seal with my Sony Isolation tips. Definitely the longer filters would help.
Filters
This time Bob told me just to use the filters from the Atlas. There isn't a lot of difference to be fair – mainly differing amounts of bass. My favourites are definitely the gunmetal (lightest bass), and to be fair, the red do add about 4-8 dB between sub and mid-bass, which will give some of you quite a lot of room to move.
Sonic Signature
The mid-range is pretty much the same as last time, a slight dip from about 800Hz-1kHz, then a rise through the upper mid-range. This gives the impression of a bit of distance which helps sound stage impressions. What I love though is how clean and clear this new tuning is. They are magic with female vocals – with anything really. If you liked Bob's tuning with the Atlas, but wanted a little less bass presence and a little more mid-range focus, you'll love these.
Male vocals are probably a little lean – they were on the Atlas and original Delta too. It's something you get used to pretty quickly anyway. What I really like with these is how clean they are. Very detailed – and they have a good grasp of overall fine detail (cymbal splashes etc) without triggering my sibilance.
Improvement?
So – are they an upgrade over the Atlas? For me yes – I was never that happy about the Atlas bass – it was just too much for my personal taste. The Sabre seems to have better control over the bass overall – its much better behaved, and a marked improvement over the old Delta as well. I can't compare to the Master as I'd need to have the two side-by-side, and I think Bob has more tuning to do with the Master before it is released. The Sabre is ready though. It's pretty darn good too.
Delta 2
I can't compare this with the Delta V2 at the moment – because unfortunately one of my drivers is bung (replacement coming – it happens – nothing to worry about).
Great cable - longer body
Usual high quality cable components
The longer Delta V2
What I can do is show you some pics of the Delta V2, and show the measurements of the good driver with the different filters. First, the fit on the Delta V2 for me is very good. They protrude a little more – but I'd still be able to sleep with them in. A lot will depend on your own anatomy – I have big canals so I can get quite a good deep fit. The shells are 12mm in diameter, and about 23mm from nozzle tip to the rear of the shell.
Filter mesh
Removable cable connector
Rear port
The filters this time are one of the reasons I really liked the original Deltas. It isn't simply a variation on one aspect of the sound – much like the recent Atlas, and some other IEMs from other manufacturers (T10/T20 etc). This time there are some filters which are hollow, and some which are also internally damped. The range of changes is really good with these options – and it affects both upper mids and also mid-bass down. Total changes of all filters and also a single example of gold damped vs undamped is shown.
Inside the Delta V2 + damped filter
Other side of the filter
Full range of filters
The Delta V2 comes with
1 pair gun-metal (damped)
2 pairs silver (one damped / one hollow)
2 pairs purple (one damped / one hollow)
2 pairs gold (one damped / one hollow)
Close up of purple - note tiny ports + damping
All of the filters
Damped vs undamped gold
And with this you can go from relatively balanced to very V shaped. I love it, and can't wait until the new driver shows up.
Bob – this is still the way I would personally run all your filters. It gives so much more control over very different sonics.
Ranking?
So how would I rank what I've heard so far?
Subjectively. I'd put the Sabre ahead technically – it is just super smooth and effortless, but for me the filter choices on the Delta V2 put it on equal footing. If the Sabre had the same filter choices - no question it would pull ahead. I'd rank old Delta next (I've always had a soft spot for it – again it comes down to tuning and filter choices). Atlas would be last – but again I need to stress that its just my personal thoughts on having too much bass. When we are originally tuning the Atlas, Bob sent me a pair of black ones – perfectly matched with the bass driver turned down quite a bit. I still have them and love them. They are unique. I know a lot of people love their Atlas – its just not my favourite sound.
Final question – what does Sabre most sound like. Tough question! It's pretty similar to Delta V2, but thats probably not helpful. So the other earphone I'd say it is relatively close to would be Dunu's Titan T5. Similar bass and upper mid-range signatures.
If anyone has any direct questions I'll try and answer them – but just remember:
- I don't have the Master with me.
- The Sabre is not final (but I thinks it is pretty close to final tuning)
- My Delta V2 is unfortunately broken, so I can't give you an idea of true comparison.
And here's a quick look at the size of the Delta V2 vs the original.
Old vs new Delta
Main difference is length
Very similar width
Apr 23, 2016 at 10:45 AM Post #3,551 of 4,830
Thank you Paul!
One question : there's hardly any secret that the mid bass on the original Deltas was too much for my preference so how's the quantity on the Sabre in comparison?
Apr 23, 2016 at 6:17 PM Post #3,552 of 4,830
Another question from me. Had the Titan 3 and 5 a while and really got along well with the T5 so nice to hear they may be like the T5 signature. Any chance you would be able to say if you think the Sabre is better than the DUNU technically??
Not that it matters because I pre-ordered already so I have a Sabre coming
so I'll be able to answer my own question.
I'm all for the addition filter options for the Sabre as well. The Sabre come with plenty but they could for sale as a optional item. I know I would try them out. I'm assuming the Master has something to that effect with the mention of normal and "fun" sounding filters though that may not have been final.
Apr 23, 2016 at 8:45 PM Post #3,553 of 4,830
Thank you Paul!
Hi Peter
You can dial it in - and it's much better behaved (less boomy).  Below is Delta V1 vs V2, and also vs Sabre (gold) and Sabre (gunmetal)
The Gunmetal is my favourite - clean and clear (green line on the graph) - old Delta is the yellow line.
Apr 23, 2016 at 8:48 PM Post #3,554 of 4,830
Tough call - slightly different in their presentation, and both are exceptionally good earphones.  I don't think I'd like to say one is better than the other.  Sabre gives you the chance to alter bass quantity to your own liking.  If Bob plays around with some other filter combos (internal damping) then you'll have even more options.  Love the T5 as well though - so I wouldn't be able to pick a clear winner.
