Introducing the LCD-i3
Feb 27, 2024 at 7:32 AM Post #1,036 of 1,041
A used i4 is only around €3-500 more than a used i3. These iems really don't have have driver failure from all finding I've seen. Mine has lasted 4 years. The difference between the 3 and 4 once you correctly use auto eq 20-6000hz is about 25% improvement in performance. The i4 is far more effortless in its presentation than the 3, much like the lcd4 is once corrected. Its like the difference between a almost spotless window, and no window at all. Like the driver is completly imperceptible, or is ethereal like a E-stat. None of these iems should be used without serious EQ like a qudelix. Their defult FR's are abominable, but the i3s is noticeably better than the i4. Like going from a E to a D+. Technical performance wise, it's going from a S- to a S+. For such a small difference on the used market, that is worth the jump every time, but absolutely not for $1500 more brand new. Its not that large.
agree with everything you wrote, except the eq thing, as i think frequency response is mostly a personal thing and a matter of preferences and taste.
Apr 8, 2024 at 8:12 AM Post #1,038 of 1,041
That's the upgrade I made.
For me the only one that's worth it.
Apr 9, 2024 at 2:35 AM Post #1,040 of 1,041
Yes
Apr 12, 2024 at 3:01 AM Post #1,041 of 1,041
Happy owner of lcdi3. Looking for possible upgrade. Any suggestions? I know lcdi4 is a natural option but I use them mostly on the go.
So lcdi3 to me sounded like an LCDX more than an LCD3. If you can stand a bit smaller stage I'd definitely try a 64 Audio Duo
