A new firmware for P6 Pro has just been released (1.0.4) and with my very preliminary testing it seems fixing the long awaited wrong indexing issue. Please refer to below Google Drive for download of the firmware.
1. The number of recognizable songs has been increased to 20000.
2. Supports FLAC and WAV ID3V2.
3. Fixed some Japanese.
4. Added sound style function
(Download the latest DSPConfig.bin file and put it in the same location as FW)
Hi folks
Can the volume be changed on P6Pro in DAC mode and is not just on or off as I read in some older review?
Any issues with upper mids for people using the Traillii?
I read here that DAC mode is working from Ipod Touch.
So I guess it will also work from IPhone /IPad / Macbook Pro?
Hi folks
Hi folks
Hi chaps
Some more interesting questions for potential buyers
1. Does usb allow direct file transfer to micro SD card?
Edit: answer found in this thread https://www.head-fi.org/threads/interesting-machine-from-luxury-n-precision.918288/post-16379996
2. Anyone using the P6Pro as USB DAC with latest MacOS / IOS ?
3. Do you know which UNIX is running as OS on it?
4. Anyone tried using Airplay from IPhones which would be a great alternative to LDAC for Android using Apple devices allowing CD quality 16/44
Hi chaps
Thx, anyway it's closed shop implementation.
But as a former Unix user I am wondering which additional features could be suggested to L&P to make life easier...
The whole library topic is hopefully being resolved when developers are finding time.
Much more interesting is the network interface - it's only Bluetooth and not WLAN though, right?
So there's no IP stack implemented as of now I guess.
Reading some interesting comments in L&P W2 thread about using the likes of Bubble Upnp for hooking up streaming content was raising some ideas in my head...
So what I mean is to stream real hires flac files over some Linux server daemon running on P6Pro but if only Bluetooth is available hardware wise that might not suffice in terms of bandwidth and latency...
Yes, it's only Bluetooth. I don't use streaming that often, and the Bluetooth mode is pretty good, so I don't really mind it being Bluetooth-only. It would be pretty nice if they were able to implement Bubble UPNP for those who use it though.
I can think of a few features L&P could probably implement:
24-bit/192kHz support in USB DAC mode. Currently, USB DAC mode is limited to 16-bit/96kHz. Not an issue for me, but certainly a problem for people with higher quality tracks.
Actual EQ. The EQ in the P6P is just presets. I don't use EQ though
Gapless playback. Currently, the P6P doesn't support it and it's pretty annoying for me.
A visible volume counter on the screen when the P6P is in USB Audio mode.
The bottleneck of P6P, accordingly to Mr. Wan, is that most of the processing power goes to audio-related calculations and so little is devoted to the OS. They do so mainly to reduce the noise floor.
If you check out N6ii R01’s latest updates from Andy, you will see him keep mentioning of the high noise floor with R01, which virtually makes it unusable with C9.
