ajchen
- Jan 6, 2016
Is this the one that was posted a few weeks back?
Yes , it should released about 1 or 2 weeks ago . I had no any issue with v1.0.0.4 till now .
Which tag editor do you recommend?Just spent the past few hours organizing my library tags so they look clean on the P6 Pro. Under “all music” the P6P reads the file names and not the track ID, you can download an mp3 tag editor and one click swap your track name to file name (assuming your track names are correct) and everything will display correctly on the P6 p.
The one I got was free from mp3tag.de
I can post a before and after from when I had the demo to how it looks now to help visualize the difference once my SD card finishes syncing
I’d appreciate seeing that!
Thanks Bobby, I agree that is a nice improvement. Probably worth doing on my end too - weekend mini-project!So it’s not the best visual but it should be enough so you can understand why it was a problem before. I’m not sure if you have used the P6 Pro or not but it doesn’t have a search function and the “all music” tab reads tags from the file name and not the track ID tags itself. Here is a picture of it reading file name tags only:
As you can see it’s all out of order and incorrectly sorted which made finding tracks almost impossible this way.
What I did was used a tag editor and I replaced the file name with the track ID tag instead so it looks like the “all music” is reading track ID names instead of file names, you can notice the difference on the song “blind spot” pictured in both.
it isn’t a perfect solution but it does make finding tracks by song name MUCH easier since it is alphabetized by track name. Let me know if you have any more questions.
Great, a good way to make the otherwise useless Allmusic be good for something other than playing in random.Here is what I mean, the one that says (Trivecta Remix) is the original file name, the rest I just added the artist into the title to make them not error.
You still on firmware 1.03?Grrr just experienced my first crash with the P6 Pro while trying to add songs to a playlist. It froze and when I got it unfrozen all the progress I had made was gone. That was… super… annoying.
Me to.Yes, i was lead to believe 1.0.0.4 wasn’t actually officially released yet?
