So do you guys think that we should pre-order the iem while the time remains?
I did. Can't beat the price. Plus, you won't be charged until it ships.
BTW, I did the vent mod on the R1 and it has helped with the driver flex and does seem to have more controled bass with a larger sound stage. Basically, it's what Bob is doing the newer larger vent on the zeniths on a smaller scale. I opened the shell with a torx 4 bit, removed the smileys with small Phillips head, and drilled through the current two holes with a 1/16 drill bit. I then went with a 5/64 bit after to double, almost triple the size of the regular two holes. This was quite an easy one but I did have to re-expoxy my mmcx connections that I added last time.
![20181205_180111.jpg 20181205_180111.jpg](https://cdn.head-fi.org/a/10208559.jpg)
