Hi guys, Im about to pull the plug on buying a JVC spiral dots but unfortunately im really confused with the sizing they have small and MS and M size, large is obviously not my size, so can someone help me is this a good buy?? and with comply my size is small, with spin tips my size is medium the red one, the purple is too small for me as I can hear outside noises, please be adivsed. and does balanced cable really improve the sound of imr r1 significantly?? Im thinking of getting DAP
Hi, I've never tried Spiral dots so I can't answer that.
But I'd recommend Symbio MandarinE tips. They're a hybrid tip with memory foam bonded to the inside of a silicone outer. They come in standard or wide bore, and for me, give the best sound of any tip I've tried. Mind you, this will no doubt vary depending on source, IEM and so on.
Regarding balanced, I'm not sure how much you know, so please forgive me if I come across as explaining stuff that's elementary to you lol.
I'm not an expert either, but here's my answer to your question in, ahem, Layman's terms
Having a balanced cable in itself is meaningless, unless you're plugging it into a balanced socket on a balanced source.
If not, then (assuming you use a balanced to single-ended adaptor), then it's just a question of the quality of the cable.
Now single-ended vs balanced seems to be a mildly contentious topic on here.
My take on it, based on reading around on here, is that really it's not that balanced is necessarily better.
It's more to do with how skilfully it's implemented by the designer/engineer building the DAP.
Mojo has rave reviews and is single ended. So is the excellent Shozy Alien+ DAP.
However, a general trend seems to be that in a device where there are both balanced AND single-ended outputs, the balanced one sounds better.
So if you're looking for a DAP, I could recommend the iBasso DX150 or DX200 (depending on budget).
They each come with an AMP unit which has both balanced and single-ended (and I've found I could actually use both at the same time, to let someone else listen on another set of IEM's simultaneously!).
Balanced on both sounds better. Interestingly, the AMP units can also be changed; they have others for sale (single-ended, balanced, 4.4mm balanced), all with different sound signatures, so you can experiment and find out which suits you.
I believe Fiio also offer this, but I haven't tried theirs so I can't comment personally, and I don't know if their default AMP units offer both single ended and balanced in the same unit?
