I'm excited to hear them for sure. Its just I only really use IEMs at work so it's not ideal for something so open.I'm actually happy with fully open, I can still use the Zenith closed if I need. I'm very curious to spot the differences between the two. According to Bob, "Shipping is approximately the end of June".
IMR - R1 Thread
- Thread starter AudioJunki3
Overclocked11
I will check out final type e , spiral dots , symbio w and spin fits . But will be next week . I will report back
Thanks so much for the suggestion.. the Final E tips are easily the best I've tried yet with the Zenith
I also grabbed some Spinfit and they are good, but not as good for fit as the Final. They definitely help control the brightness as well.. great pairing.
Please can you measure the width and height of the Final E tips you got? Which size are they? Trying to determine which size I'll need for mineThanks so much for the suggestion.. the Final E tips are easily the best I've tried yet with the Zenith
Final E are awesome , at the moment i use Symbio W with the Zenith , sounds really nice. i prefer these both two over all the othersThanks so much for the suggestion.. the Final E tips are easily the best I've tried yet with the Zenith
size L is about 13mm diameterPlease can you measure the width and height of the Final E tips you got? Which size are they? Trying to determine which size I'll need for mine
Thanks, any idea what the diameter of size M is?size L is about 13mm diameter
sry dont know .. only have L and LL , L fits me perfectThanks, any idea what the diameter of size M is?
would guess about 11-12Thanks, any idea what the diameter of size M is?
what differences do you guys hear with these vents open or closed ?
I do not hear much difference, just a slightly larger sound stage
mbwilson111
- Oct 13, 2016
I never even bothered to listen to them closed
Overclocked11
IMO the difference with open/closed is more apparent with the R1 than it is with the R1Z.
With the R1 I find that closed narrows the soundstage and open widens it, and gives a better airiness to the presentation. With the Zenith it's less pronounced of an effect, but still there.
Is there a little bit more bass when closed ? Or is it just my imagination
mbwilson111
- Oct 13, 2016
Filter choices will affect the bass more than anything.
