groovyd
- Jun 29, 2012
We have something special for you today. Lots of things have been said about jitter, and here's our take on the case.
SPDIF iPurifer®: Jitter Performance Test Results - Part 1/2
Background
To show what the SPDIF iPurifier® can do and how it can improve DACs from the inexpensive through to the very expensive, we used the ‘Jitter Generation’ function of the Audio Precision 2 test system to create a ‘J-Test Signal’ (the industry standard for testing and widely used by magazines, including Stereophile, USA).
The Audio Precision 2 artificially creates a specific, known amount of jitter and then measures how much it is reduced by the SPDIF iPurifier®. Hence it is quite quantifiable AND informative as a measurement tool.
The Methodology
Audio Precision 2 (AP2) generates a signal with 64,130pS of jitter (measured via loopback into AP2) using a square wave waveform at 250Hz. The specific settings are simply chosen to create a gross amount of easily visible jitter. The test results are scaled to be comparable with those by Stereophile (USA).
DACs Tested
The majority of DACs (>80%) in the market use either AKM or Cirrus Logic SPDIF receiver chips, hence one DAC using each of these was selected.
The DACs tested are listed below:
- DAC 1: AKM based, AK4113 Receiver & AK4490 DAC Chip, RRP US$400
- DAC 2: CS based, CS8416 Receiver & CS4398 DAC Chip, RRP US$500
- DAC 3: BB/TC based, TC Audio DICE Chip as Receiver & PCM1792 DAC Chip, RRP US$5,000
The last DAC was included because of two reasons; very high asking price, which indicates its high-end shelf affiliation, and its SPDIF inputs’ specific ‘anti-jitter’ circuitry. It was interesting to see how well it’d work next to DACs with ‘vanilla’ input circuitry.
Stay tuned, there's more!
but here's the thing... any usb hub will remove jitter. they all re-clock.
