I just got one. It has 5v and 15v both which are 1 amp. Sound great than generic wall wart power supply.Topping p50 is only 5V, doesnt have enough voltage for the zen stream
iFi audio ZEN Stream - Streaming elevated to a higher plane
- Thread starter iFi audio
It has a 15V outputTopping p50 is only 5V, doesnt have enough voltage for the zen stream
I'm gonna pick one of these up aswell,if it dosent improve the sound then atleast I can send it bckI replace the generic power supply from stream as well as the power supply from dac with topping p50. It improve sound quality on both and 120 dollars money spent was well worth it.
I’m hesitating between topping p50, ipower gen1 , ipower x .My stock is 15v and it sounds decent.I'm gonna pick one of these up aswell,if it dosent improve the sound then atleast I can send it bck
However I’m still hesitating in keeping the zen or buying a lindemann limetree bridge used…or just leave the whole thing and use the hegel h95 built one.
My observation between wall wart and topping p50 was that you get the benefit of wall wart without artifacts. That’s what topping p50 did to my system. I have tried many different ac conditioner in the past but there was trade off such as loosing dynamics, texture or too smooth of the top end and loosing the bite of the cymbals.I’m hesitating between topping p50, ipower gen1 , ipower x .My stock is 15v and it sounds decent.
Vangelis
- Jan 3, 2002
What Voltage, amp and wattage did you select?I'm really happy with my Gieseler Kraftwerk II Dual linear power supply. The Stream and its DDC buddy are both powered by the unit and I couldn't hope for a better sound out of my monitors. I'm a clean power convert now. Always thought voltage and wattage is all than matters but it turns out I was wrong. Makes you wonder why high end DAC and streamer manufacturers focus so much on their power supply section...
Thanks
The source has two adjustable outputs at 5, 7, 9 and 12V, each at 3A. For my application I have set it at 9V for the X-SPDIF 2 and 12V for the Stream.What Voltage, amp and wattage did you select?
Thanks
2s
ifi sent me ipower 2,but it took the enjoyment out the music,I’m hesitating between topping p50, ipower gen1 , ipower x .My stock is 15v and it sounds decent.
winged creature
- Mar 15, 2005
I guess I missed that. Wonder if you could use both the 15v and 5v at the same time.I just got one. It has 5v and 15v both which are 1 amp. Sound great than generic wall wart power supply.
- Output Power:
- DC5V 1A*2
- DC15V 1A
- DC5V 1A*1+DC15V 0.9A
- DC5V 0.8A*2+DC15V 0.8A
I’m using both at same time with stream and dac. No problem powering them both.
- Output Power:
- DC5V 1A*2
- DC15V 1A
I have both ipower and ifi ac purifier that it made music too smooth at top end that it lost shimmer of cymbals.2s
I have been waiting on Spotify hifi since it’s announcements last February. Year is almost over with no news on the horizon.
mikedemunck
Been running the zen stream with the 12v iPower2 for the last two days and no more crashes/restarts. Seems that iFi ships this unit with an inadequate psu, which seems odd. I don’t notice a change in sound (for better or worse) as other did. Care to comment? @Sebastien Chiu @iFi audioYeah - it was off again this morning lol. As I say, just enough to annoy in these times when walking across the lounge (12 feet) is just too much to bear though I think the issue is having sat and settled down you then have to get up again!
shoaibexpert
I had both the P50 and the iPower stock PSU and preferred the stock PSU in terms of dynamics.
On another note, I do hear a slight buzz from my other IFI Zen Stream unit (I have 2) that is currently powered by their 9V Stock PSU. The buzz increases as the unit starts to stream music/tidal and becomes less as I press pause.
Ahas anyone experienced this? What can I do to rectify this? Contact IFI, if yes, what's the best and most efficient forum? If not, do dealers help with such issues?
Thanks
Thanks
Total: 15 (members: 0, guests: 15)
