gr8soundz
- Jun 28, 2014
Planning to buy a combo of Idefender and Ipurifier. So having a bunch of USB dongles stick out of my PC motherboard feels very flimsy, so i was thinking of buying a few IFI otg type C sandwich between the USBs to increase flexibility. So, with the good-ish build quality of IFI OTG cable, it can be a glorified usb extension to prevent breaking, sounds good ?.
Good idea, imo. I also have the iFi OTG cable along with an AudioQuest Jitterbug plus countless short USB interconnects/converters/adaptors.
I usually mix and match pieces depending on which dac and/or device I'm using. They're fairly inexpensive but combined total can start to add up however, unlike some dedicated accessories, feels like a worthy investment since most gear supports usb nowadays.
