Thanks for taking out time for writing that helpful post. Yes, I will consider the iGalvanic or iUSB 3.0 for future upgrades.
You welcome.
I have the iFi Audio: Micro iDSD BL, iPurifer3, iSilencer, iDefender, iPower (5V), AND iGalvanic 3.0.
The iGalvanic3.0 makes the most difference and the effect is similar to the iPurifier3 in that it is giving a spaciousness, soundstaging, clarity, and cleaniness to the music. The Purifier3 installed right before the BL's dac adds more of the same magic. Together, iGalvanic & iPurifer3 nullify the need for the iPower, and iDender all together according to my experiements. The iPower and iDefender did nothing after I got the iGalvanic3.0 so I took them out of my chain. So my suggestion would be to save yourself the $100 bucks and apply it directly to getting yourself the iGalvanic3.0 instead or at least--first.
Now, the iSilencer has been significant in my chain because I use generic, blue, USB 3.0 cables, and so I've installed iSilencer FIRST in the chain out of the my laptop (before the power and data packets start their journey to the iGalvanic3.0). It gives a smooth natural-ness to the music--especially to my Dragonfly Cobalt where the iSilencer is in between the iPurifer3 and Cobalt.
P.S. (I just read Alboxing's remarks above, after posting this. I guess we said the same thing--sorry about that.)
Apparently the iUSB 3.0 is sold out everywhere and iFi is not even manufacturing any more of it.
Honestly it makes sense because the iGalvanic does everything the iUSB did and plus some more. The only advantage the iUSB had was the slightly lower noise floor figure, but we are talking about insignificant difference (0.1uV iUSB vs the 0.5uV of the iGalvanic).
Also, I personally like that the iGalvanic gives you that clean power without the need for external power bricks, straight USB power up to 900mA which is really good and convenient.
Our messy audio chains could make use of some simplicity sometimes, I know mine does.
Adding the ipurifier right at the DAC input is like a final touch to assure the highest signal integrity at the PHY interface.
I read some users criticizing iFi for having many redundant/overlapping products so maybe they figured they'd simplify their product range a lil bit.
If I was short on money and wanted effective simplicity, I'd honestly just focus on iGalvanic and that's it.
It is also interesting that Condocondor found the iSilencer made a positive difference. When I tried it in series before the ipurifier, I found it made the nano's already warm sound a bit too warm (the sound gets already warmer and more "analog" from the addition of the ipurifier alone).
Like I said I also heard a "flattening" of the soundstage and also the iSilencer seems to make the output volume a little quieter on multiple usb-powered devices I had tried it with.
Maybe it creates a small voltage or current drop due to the limitations of the ANC in such a small form factor.
However as I said before, the iSilencer having a bit of a signature sound is actually very positive in some usage cases, for example to tame the bright glare some dacs may present. In this case the end result will be perfectly balanced, but my nano is already warm as it is.
