801evan
After a new wave of tinkering combinations with the idefender and isilencer as part of the Corning chain and smartphone as source playing MQA, this is the new placement:
1st: cp (cellphone) -> otg -> idefender + 900usd worth of power upgrades -> Corning -> USPCB -> DAC
2nd place:cp (cellphone) -> otg -> Corning -> USPCB -> DAC
iSilencer and coupler combos ultimately gave a sonic signature. It took this crazy amount of power upgrades to understand the power of the Corning. Each Schaffner power cable gives at least 70db of noise filtering. I'm using 5 of those plus 8x lt3045 where each lt3045 is 70db of power filtering (.8 microvolt ripple noise) and 2 AC iPurifiers (maybe 60-70db filtering). So that's a lot of filtering to beat the power noise of the CP that the Corning is filtering.
The crucial point here is I, and most Corning reviewers, failed to understand the sonic faithfulness of the Corning. For the other reviewers, they think it's darker and that's a sonic signature. But it's totally not. My CAT 8 cabling sans Schaffner power cables gave a more energetic yet smooth sound but I didn't recognize that it was rolling off the highs too much. That combination made me think it was a cleaner sound and since it's SQ was too far from the simple Corning, my brain failed to understand which is better. On a monetary and technical standpoint, the CAT 8 chain should be better. The dual front and rear idefender seemed better but it was just compensating and massaging around the noise rather than actually reducing it. So it's only after having 5 Schaffner power cables that it only brought me back to the same sonic qualities as the solo Corning!! All is not lost though. What I've gained is still a solid improvement where everything is fuller, there's no sonic signature from the components, micro-detail and nuance are rendered flawlessly, the micro-depth and separation is felt and it's all completely natural to the ear and climatic. It's still PROBABLY worth that cost coz it sounds better than a HUGO 2 TT + m scaler.
