istfleur
- Jul 4, 2015
Any comparison to Dunu falcon C plz.
IT01How do you compare the IT01 with the JVC FX850? I have the JVCs, but too much midbass for my taste (I performed your mod to tame it) and not much highs and detail.
IT01
+ more clarity, more details, sound closer to neutral side
FX850
+ deeper bass, very special sound on string instruments
These two are not easy to compare, but they can perfectly complete each other in your collection
IT01
FX850
I have no idea. Never try either of those.Thanks, I have also the JVC- FXT200SE modded without filters that are bright with open soundstage and good bass, but less lower mids, like the FiiO EX1 (DUNU Titan 1). I suppose that the IT01 are similar in sound signature to both IEMs. Isn't it?
Give them about 100 hours... they should smooth out and become less bassy.Just got these yesterday. I like the sound overall but a little too bassy for my particular taste.
Just got these yesterday. I like the sound overall but a little too bassy for my particular taste. On recordings without enough bass it's perfect, but with bass heavy recordings it's just way too much and is distracting. The detail and soundstage is really impressive though. They honestly sound more like a high end full-size headphone.
Also I'm hearing the driver "crinkling" sound from both when I insert them too quickly. I have to put them in really slowly in order to not hear it. It's making me a bit paranoid since the driver material is so thin and fragile.
Keep listening it all evens out eventually what you are hearing now is probably the mid bass blooming into the already recessed mids out of the box. I had a hard time enjoying them at first more because of the grainy treble and congestion when I turned them up and after I listened to them for an hour or two at work I would burn them in for about 8 hours a night at just below normal listening volume.Just got these yesterday. I like the sound overall but a little too bassy for my particular taste. On recordings without enough bass it's perfect, but with bass heavy recordings it's just way too much and is distracting. The detail and soundstage is really impressive though. They honestly sound more like a high end full-size headphone.
Try to do tip-rolling. IT01 is very tip dependent. Wide bore tips will make it sound less bassy and the narrow ones are making it sound bass heavy on some recordings.
