Joe Bloggs
Sponsor: HiBy
Member of the Trade: EFO Technologies Co, YanYin Technology
His Porta Corda walked the Green Mile
Just did a little work for this.
Since you're using Equalizer APO, you really want to add the Peace UI:
http://sourceforge.net/projects/peace-equalizer-apo-extension/
Regarding what I said about equal loudness contours, I've embedded an equal loudness compensation curve into the following Peace preset:
https://www.dropbox.com/s/tgtm3kmph4ics8n/70dB%20equal%20loudness%20contour.peace?dl=0
Load this and the Commands button should show an asterisk (choosing the Full Interface for Peace)--the compensation curve is being applied in the background. Music and Sinegen should sound quite different... you may tweak the EQ graphically now (including the green curve button showing a full curve that can be manipulated directly) until a sine sweep sounds even in loudness (you may also forego the sine sweep and use Sinegen directly:
https://www.dropbox.com/s/bp4dwqfv1qtdx38/SineGen.zip?dl=0
All this testing actually needs to be done at a good volume, rather than "just-detectable" levels. The goal is to make the sine sweep even when played at music-listening levels (i.e. loud and clear. Well, not exactly "LOUD". I indicated that 70dB would be a good reference volume.)
Remember to make use of the Quality (Q) variable, where higher Q produces a more narrow adjustment. Useful when you actually hit a narrow resonance peak that needs to be tamed.
Finally when you have made the sine sweep even with your settings you need to remove the equal loudness compensation curve for actual music listening. To do this, save to a new preset, then click the *Commands button and delete all the text I added inside and click Save.
Hope that helps
As you gain experience, you may be able to tweak the compensation curve to your own ears for better results.
Hope that helps
Stay updated on HiBy at their facebook, website or email (icons below).
Stay updated on HiBy at their sponsor profile on Head-Fi.
