Apr 7, 2015 at 7:40 AM Post #1,066 of 1,153
  Would anyone have an Sennheiser HD600 EQ settings file for Equalizer APO?  Just want to dial down the midrange a little bit and maybe boost the sub-bass (or whatever exists of it).  The parametric GUI software I'm using is less than user friendly and keeps crashing for whatever reason.
Filter Settings file
Room EQ V5,01
Dated: 29.02.2012 20:04:50
Equaliser: Generic
Filter  1: ON  PK       Fc    33,3 Hz  Gain   7,0dB   Q  1,0
Filter  2: ON  PK       Fc      75,6 Hz  Gain   -1,3 dB  Q 1,0
Filter  2: ON  PK       Fc    112,5 Hz  Gain   -1,1 dB  Q  2,02
Filter  3: ON  PK       Fc    152,0 Hz  Gain   -1,2 dB  Q  1,93
Filter  4: ON  PK       Fc    220,0 Hz  Gain   -2,9 dB  Q  0,72
Filter  5: ON PK        Fc    3300,0 Hz  Gain   -3,0dB   Q 1,0
Filter  6: ON  LS       Fc    17700,0 Hz  Gain   -7,0 dB
Save the text above in a text file called sennhd600.txt. Then, find the config.txt in the config folder of EQApo and edit it to include the sennhd600.txt file.
Apr 7, 2015 at 9:29 AM Post #1,067 of 1,153
Room EQ V5,01
Equaliser: Generic
Just a word of advice, it's better to avoid boosting at any frequencies, to avoid clipping. Better to cut the rest of the spectrum. My ear buds have the following EQ curve, for example:
Apr 7, 2015 at 1:11 PM Post #1,069 of 1,153
Jul 24, 2015 at 7:31 AM Post #1,070 of 1,153
Hi everyone,
I've followed this EQ thing (mostly), and I just think this is the most important post in head-fi, probably.  I've done quite a bit on my modded TH900s using Equalizer APO (w/ Peace GUI). Also did a little work on my HD800 (with Draug 2 cable). Let me see if I can get some graphs/settings to post here.
Jul 24, 2015 at 11:54 AM Post #1,071 of 1,153
... and I just think this is the most important post in head-fi, probably.
Even if you do say so yourself!
... oh you mean the most important thread
(Sorry, just teasing ... and made 100 posts now!
Jul 28, 2015 at 7:14 AM Post #1,075 of 1,153
HD800 responds to EQ like no other.  The sound stage will widen amazingly with greater detail - you'll love it  . . .
I beg to differ. The cheapest headphones will often have the most to gain. I EQ'd some very cheap ($20) headphones and they improved beyond recognition.
Jul 31, 2015 at 12:31 AM Post #1,077 of 1,153
RE: How to equalize your headphones
 Hello,
We can see lot of headphones curves offered by different sources. What is the reliability level of such curves?
I would like to offer some criteria to judge is some Amplitude Frequency Response curve reliable or not:
 – can we create an equalizer based on such curve and is such equalizer removing problems (sound coloring) and does not add new ones?
The accurate and reliable measurement shows that it is impossible to characterize some headphones model by only one curve. The curve is different from one pair to another and even between two drivers of one pair of headphones.
Please visit this measurement collection  http://aplaudio.com/conc2/knowledge/equalizing-headphones
and try to determine which 6 pairs of curves are representing 6 pairs of Sennheiser HD600 headphones. Same thing with Sennheiser HD650 4 pairs.
Aug 6, 2015 at 5:34 AM Post #1,080 of 1,153
If I understand correctly, this 7.5kHz resonance peak is only with headphones because of the ear canal.
This means that mic measurement without simulating the ear canal mean nothing.
So what about these 2000$ planar magnetic headphones that measure very flat?
But what about speakers?
Completely flat speakers in an anechoic chamber will sound completely flat to our ears?
Testing with my studio monitors, I can say that there is NO resonance in the 8khz range, but with my headphones (ath-m40x) I can clearly hear a huge 8kHz peak.
Does that mean that individual headphone EQ is mandatory to achieve flat response for better monitoring?
