castleofargh
Sound Science Forum Moderator
- Jul 2, 2011
I agree about what can be found, and also that IEMs are definitely where we'll find the most extreme examples of cables, or really anything influencing everything else. The IEM market is organized chaos. Even without counting the rare cases where the cable is part of the design and gets some atypical specs on purpose(so of course replacing it by some random cable will cause a bigger change), we can still get strangely large impedance values at times. At least large compared to what we should expect when thinking of a basic 1.2m cable.That is what unfortunately may very well put you, " science guys" in the very same category as the cable beleivers.
Here you are - the routine IEM stock wire- 0.8-1 Ohm per wire, two of them in the circuit. They should be flexible, otherwise they become unusable, so the coat hanger wires do not do trick here
Pictures attached below.
True that the trend in designing IEMs with the impedance below 16 Ohm can be viewed critically, especially that the values cited just at 1 kHz, the transducer resonances can give even lower values
Nevertheless, that is how cables matter, matter for the frequency response, and quite appreciably so in many cases.
For those who sort of care, @hakuzen spent a great deal of time and some money to give us those lists of measured resistance:
https://www.head-fi.org/threads/resistance-of-cables-pics-comments-and-links.907998/
It's only one side of the electrical game, but it's already a great deal more informative than spamming the same unsubstantiated stuff like a bot. Speaking of which, @InstantSilence is out of the thread for a week.
