bigshot
What is the SourceAV and what do they sell? Are you a high end audio salesman?
A controlled test or I get to call it as placebo! Even a casual controlled test would be fine. This ain't Kansas. You're in Sound Science now. Just saying, "night and day" and "even my wife can hear the difference" won't cut it around here.
USB is digital. It can't have veils or wider soundstage. It either transmits the data cleanly or it is riddled with dropouts or artifacts. If you are hearing veils and soundstage, you are hearing 100% USDA prime expectation bias.
You've got my interest now. Can you please link to the report on your test? I'm sure we would all be interested in it. Did you compare those two against known transparent DACs to make sure one wasn't defective? Which one wasn't transparent? Is the source AV a club of some sort, or is it a store?
Did you check the setup to make sure that they weren't monkeying with the signal on one or both? I have had VERY bad luck with high end audio retailers when it comes to honesty. I wouldn't trust them as far as I could throw them.
YOLO?...?You assume all the measurements are even looking at the right thing or everything that can make a difference.
And personally, in the end, I don't care what the numbers say or don't say, or if we're even looking at the right set of data in the first place. If I can detect a noticeable improvement, I keep the cable. If I don't I return it thanks to the return policy.
I have no need to prove to any of you because you're not here to listen to my system to make that judgment firsthand, so it doesn't matter really.
YOLO?...?
Seriously, believe what you want to believe because I won't make you change your mind.
By the way, it's not like different cables will always sound substantially different or better.
I don't use my system a lot, I use my headphones straight out an USB-C to 3.5mm because it is more comfortable and more practical than always being connected to an amp. Also I get better volpot balance using that little piece of engineering. It measures well and does its job splendidly.How many USB cables have you actually tested back to back and on what system?
The ones that sound the same are more likely to be correct.
Obviously you have a high end USB cable. Would you like to lend it to us at Sound Science to test it against an Amazon Basics one? We have people here who are experienced in doing controlled listening tests who would be happy to oversee it and make sure it is accurate.
I don't use my system a lot, I use my headphones straight out an USB-C to 3.5mm because it is more comfortable and more practical than always being connected to an amp. Also I get better volpot balance using that little piece of engineering. It measures we and does its job splendidly.
I have not tested any cables and never felt the need to do it since there's solid science behind it, and I'm not an outlier, and even if I were, I would not be able to hear any difference anyways since is way beyond human capability to do so.
I will give you some piece of unwanted advice, yo enjoy music you don't need cables, amplifiers or gear, you need to bring your soul and open it for this sensorial experience. Close your eyes and forget about everything else, about the forums and the discussions, and you will truly enjoy music.
I haven't felt the need to.You haven't even done any of the tests yourself.
Who's him? Not to brag, but I have better ears than him just due to age (I'm just 21 and still can hear 20 kHz, and it is really unpleasant).Paul McGowan
First of all, the ears convert the sound pressure into electric signals, so if the ear does not pick it up, it does not get converted as part of the signal. Second, I wouldn't trust the brain as an audio analyzer, it is full of biases and psychoacoustic effects that cannot be fully separated from the goal of a test.it's not just about the ears but the way the brain interprets the sound signals.
