kmmm
- Jan 25, 2017
That is interesting if it does...I'd like to know your findings. But I guess a "significant" dip (at 3k) will be related to other issues? Sounds like a phase issue to me:Does anyone here have a simple answer for how bends in tubes affect the resonant peaks or if they don't?
If the tubes are just slightly different length or the dampers are placed slightly different you will get mismatch. I guess you have checked polarity?
You could also measure the components in the crossover to check if these are matched. They tend to not be...
Measure the drivers one by one on each side and compare. Which drivers are you using?
And if you decide to remove the drivers you'll be fine. You won't destroy them. just be careful. I do it all the time
