Now i only need Susvara.
The sheep they were made from hadn't bathed in a while, that's all.
Stay updated on iFi audio at their sponsor profile on Head-Fi.
I believe that that AMP-13R possesses one transformer within that largest "foot".And functional from what I can tell, they look like thermal exchange nodes.
Behemoth it is.Just for fun, and because pictures are always nice! Most definitely the thickest headphone cable I've ever used.. Thanks to @Joeyjoe26 who lent me his Toxic Cables Venom build to try with the Susvara.
Compared to my AC Palladium, which is dwarfed by that behemoth which would not look out of place as some rigging on a boat...
That's my Kind of cable!
Unfortunately it is no longer in the lineup
@Joeyjoe26 can you tell us a few details like gauge in awg and Material composition?
Edit: Found the answer on Google, it's 8x18awg pure OCC silver. That makes it even bigger than the Norne Silvergarde S4 8-wire
Wow that's impressiveI believe that that AMP-13R possesses one transformer within that largest "foot".
Susvara 100%Hi I have a question for Susvara owners who also have the TT2
Currently, my set up is HE1000se with Hugo TT2 with Roon-HQPlayer-Qobuz-Tidal
I have the opportunity to get either:
A) Susvara (to be driven via TT2 balanced XLR out or speaker amp) or,
B) M-Scaler
Surely either option will result in a noticeable step up in SQ. In your opinion, which of the above options will give me a bigger SQ improvement?
If you already have a TT2, I would recommend the following upgrade path steps;Hi I have a question for Susvara owners who also have the TT2
B) M-Scaler
Thanks for the recommendation, this seems to be quite a good upgrade path with some room for flexibilityIf you already have a TT2, I would recommend the following upgrade path steps;
1) Susvara (initially run them off the TT2 balanced XLR outputs)
2) Decent Speaker Amp i.e. a Chord Toby if you want to keep the same format as the TT2
3) M Scaler
4) Decent BNC cables to connect the M Scaler to the TT2 (WAVE Fidelity STORM are excellent)
5) Decent headphone cable for the Susvara
