The reason I ask is because the Susvara apparently requires only 3.49 Vrms (=159mW with its 60 ohm load) to output 105 dB (
calculator). The KANN Alpha does 12 Vrms, so I was thinking it would be way overkill.
I am actually very confused by everyone recommending what seem to be very overkill amps. If the 83 dB/mW figure is right, you all should be blowing out your ears
well before utilizing the full range of the amp. This clearly isn’t the case, so I’m wondering where the calculations are wrong. How are you guys managing to utilize even a fraction of say, the Bakoon or speaker amps’ output? When buying an amp for the Susvara, what specs did you look at to determine if it would be sufficient?
Either Hifiman put down incorrect specs for their $6k headphone, or something else is going on here, but I can’t put my finger on it.
