dcguy73
Formerly known as dc_guy
Take them where?I understand but I would rather take my HE1000SEs with me than my Susvaras.
![Beyer Smile :beyersmile: :beyersmile:](https://cdn.head-fi.org/e/headfi/beyersmile.png)
I don't think the Hypsos can power both in parallel?I've had my Susvaras hooked up on a Roksan K3 power amp behind an RME ADI2 DAC. All this talk of Ferrum has me wondering if switching to a ADI-2 -> OOR, with the HYPSOS powering both, would be a noticeable upgrade? Does anyone have that setup?
Ferrum sells a split and a DC cable compatible with the ADI-2, I thought it was precisely for such setups? Am I mistaken?I don't think the Hypsos can power both in parallel?
Uh that must be a new thing then, wasn't aware there's a splitter and I'm sure that wasn't available when I owned one.Ferrum sells a split and a DC cable compatible with the ADI-2, I thought it was precisely for such setups? Am I mistaken?
Yes, see https://ferrum.audio/product/power-splitter/Uh that must be a new thing then, wasn't aware there's a splitter and I'm sure that wasn't available when I owned one.
Just make sure settings fit for both
I did get to try it later on. USB C actually sounds good on the go Blu. Would be a better option if one isn't doing ldac. oddly I like the USB input of the go Blu and go bar over the gryphon. I already tried to break in the USB input of the gryphon for 5 days but it still couldn't catch up so....maybe it needs more break inDid you try the USB C portion? Thinking of getting a portable dac/amp for my cellphone. Thanks.
Yeah, so it turns out that to properly break in a USB input, you need to plug and unplug the cable repeatedly. Doing this for 8 hours straight will assure full break-in. It doesn't have to be nonstop, but if you take a break, it shouldn't be for longer than 15 minutes, or else you have to start over with the 8 hours. Definitely a pain in the arse, but you'll thank me later, although your wrist probably won't!I did get to try it later on. USB C actually sounds good on the go Blu. Would be a better option if one isn't doing ldac. oddly I like the USB input of the go Blu and go bar over the gryphon. I already tried to break in the USB input of the gryphon for 5 days but it still couldn't catch up so....maybe it needs more break in![]()
Not surprised to see cheap shots from team speaker amp, but carry on.Yeah, so it turns out that to properly break in a USB input, you need to plug and unplug the cable repeatedly. Doing this for 8 hours straight will assure full break-in. It doesn't have to be nonstop, but if you take a break, it shouldn't be for longer than 15 minutes, or else you have to start over with the 8 hours. Definitely a pain in the arse, but you'll thank me later, although your wrist probably won't!
Communicating with Hifiman customer service is becoming a painful experience, as my Susvara are still in pieces after more than a week since communication started, 12/5/22 to be exact.Sorry for the inconvenience. Please be assured that we will solve it for you asap.
I'm not dead serious at all, I just know that head-fi tends to blow everything out of proportion especially when its regarding potential new products, and especially potential new flagships, so all the disclaimers etc...in my post are simply trying to provide a sliver of rationality to the whole situation.hey, no need to be dead serious, no one knows if the model name will be v2 or se or a different name, just a teaser, if you want official announcement there will be a new kid in town or it won't happen at all, everything could be so "baseless", there's always a bit vague in the bussiness, it ain't science peer-review
