HiFiMan Susvara
Aug 15, 2018 at 6:49 PM Post #1,591 of 25,688
Yes, my ultraRendu (plus LPS) was my previous Roon endpoint, and I replaced it with an iPad.
Some people report the iPhone X is even better...
I found it depends on the USB cable used. I tried a long Meego cable which is Lightning to micro USB and there was a distinct drop in sound quality. I used to run various iPads through a Schiit Wyrd to a Hugo or Hugo 2 with good results though.
Aug 15, 2018 at 6:57 PM Post #1,592 of 25,688
I may try it. I have an iPad Pro. Just need CCK and install Roon trial. It would be crazy if it sounds as good as an ultrarendu and lps.
Aug 15, 2018 at 7:11 PM Post #1,593 of 25,688
Joined the club today. My initial impressions are wow. Live music sounds so life like. There's a lot of air around the notes and the extension is outstanding at both end of the spectrum. I'm testing them out with my Pro iCan and Hugo 2. Gain set on 9dB volume around 11 o'clock and they are plenty loud and musical. I'm trying to decide if I like tube or solid state mode better. Time for some more listening.
Aug 15, 2018 at 8:22 PM Post #1,594 of 25,688
I use a very short JCat USB cable, and an Audioquest Jitterbug, which has made quite an impact too...
Aug 15, 2018 at 8:32 PM Post #1,596 of 25,688
the ican drives the susvara with ease and sounds great
Aug 15, 2018 at 8:57 PM Post #1,597 of 25,688
Aug 15, 2018 at 9:44 PM Post #1,598 of 25,688
Yes it does. I'm enjoying the pairing a lot so far.
I own both the iCan Pro and a V281 headphone amplifier and I much prefer the V281 when driving my Susvara headphone. Both headphone amps are powerful enough to drive the Susvara, but I find the V281 to be much more "musically accurate". I only realized how large the difference between the two amps is after I purchased a Wyred-4-Sound DAC that increased the resolving power of my audio system. See my personal review to better understand my set of personal biases - https://www.head-fi.org/threads/wyr...mited-edition-dac-appreciation-thread.874370/
Jeff.
Aug 15, 2018 at 9:55 PM Post #1,599 of 25,688
I also bought the HE-Adapter just to see what it was like driving the Susvara’s directly out of speaker taps. As good as the Pro iCan is as a headphone amp using it as a pre-amp connected to my Burson Timekeeper power amp with the Susvara's is leaving me speechless. I’ve never heard a headphone sound so good in my life. I am flabbergasted at what I'm hearing. The more power you can give them the better they are going to sound. They welcome the power and respond accordingly. The sound quality is amazing!
Aug 15, 2018 at 11:09 PM Post #1,600 of 25,688
i have both the 281 and ican and i think they are both outstanding....power wise both have more than ample power...i do love the versatility of the 281 in terms of the pre gain flexibility which allows me to pull back some of the power when listening balanced...obviously the ican has a million options as well
Aug 15, 2018 at 11:26 PM Post #1,601 of 25,688
Let me suggest an Audioquest Jitterbug between CCK And USB cable. The impact was clearly way above the (low) cost...
I have an iFi iSilencer feeding Pro iDSD which has micro iUSB 3.0 built in. You think that's enough? I think iSilencer does similar things as the Jitterbug.
Aug 16, 2018 at 10:19 AM Post #1,602 of 25,688
I am intrigued by the possibility of getting better sound from my Susvara headphones by using a speaker amp. What are the major differences in sound quality when using a speaker amp? Also, how do you avoid the possibility of damaging the Susvara headphones when using such a powerful speaker amp?
Jeff.
Aug 16, 2018 at 11:42 AM Post #1,603 of 25,688
@JeffMann To avoid any damage to the headphones I use the Hifiman HE-Adapter found here:
http://store.hifiman.com/index.php/he-adapter.html
The sonic benefits I'm hearing are better bass definition and control. Everything sounds so much more open and transparent. The bass is deeper, the mid range is spot on and the clarity is off the charts, at least with the gear I'm using. The sound is so big and lively.
Aug 16, 2018 at 11:59 AM Post #1,604 of 25,688
How does the HE-adapter protect the headphones from damage? Does it have fuses or some other inbuilt device to limit the power output of the speaker amp?
I am also interested in knowing which speaker amps are best suited for use with the Susvara.
Jeff.
p.s. By the way, I am willing to sell my Ican Pro (which is in mint condition) for $1,000 if any person is interested - because I am not using it at all.
Aug 16, 2018 at 6:44 PM Post #1,605 of 25,688
Jeff.
Must be resistors inside of the HE adapter.
