No end game for sure. LOL
The only problem we have is the curiosity. The curse of this hobby.
Absolutely! My poor, poor wallet.
Actually I sold my SR-009 because I ended up reaching for the Utopia more often. Better treble response and less fatiguing.
To me, every non-electrostatic headphone's treble is one-note, lifeless, and really just complete trash compared to that of the SR-009, a similar jump to going from something low end and not respected to something really good. I do believe (recall that) electrostatic tech has some significant inherent benefits in upper frequency response, but I'm no expert on the subject.
hello, how do you know that the Qutest is the best dac how many other dac's have you try, ....... and compared, .......For those who need a new DAC for Susvara, Pro iDSD is spectacular. I don't think many can say another DAC is much better than the Qutest. The Pro iDSD really is special. It adds a layer of dynamics that I didn't think Susvara has. Susvara can hit so hard with the Pro iDSD, it's quite a joy to listen to.
I have for the moment the T + A dac 8 and you can believe me that I made a lot of comparison, the T + A has 4 dac per channel, with a map much more elaborate than the Qutest, what do you think of Qutest's diet, ........ when you listen to chord, it's cold, no heat, there's no life in the music, even the chord TT was a failure, though 4500 €,
it's been a while since I'm waiting for the iDSD pro, and I can not get one ready,
if I will have to bet on a dac it would be rather the iDSD pro, by the technology used, like the USB output very elaborate, ........
Sold my LCD-4 and utopia to fund the susvara to pair with my phi...I think I have finally found my perfect pairing...well I hope so!.....susvara does indeed need serious power but so does the Phi
attention to the effects of fashion, many people dive with the susvara, it is easy to have a headphone to 6000 € and after, ..... that material to make it work, it is easy to say that a headphones do not work well, whether it's a lcd4 or a utopia, the headphone amps should not be the same, two resolutions totally different, .........I could be interested in a similar pairing in the future … would you please elaborate on how these two TOTL headphones complement each other in your opinion?
hello, the lcd4 can not be worse than the 009, or the 009 less good than the lcd4, these are two helmets totally opposite, ........Treble quality and resolution is the main reason I'm loving 009 more than Utopia and LCD4. It is no contest! 009 bass is fine (great, even) to me w/ a KG amp. May not be LCD4 in quantity, but it surpasses LCD4 in quality.
hank you to confirm that to operate a headphone requires a dac and a headphone amp, the soundscape will be more beautiful, wider and better holding in the bass,I've just been listening with the Susvaras from the Audiovalve Solaris using the Pro iDSD as the source. It's a great combination.
practically all helmet owners had a stax set, personally I had the 507 headphones and the stax headphone amp limited with two ecc99 tubes, with the stax set I never could listen to a full opera. ..... with stax one does not listen to an artistic work but a technology,
that the lcd4 do not like, quite agree, ..... my reproach on stax, it is not the helmets that are involved, but the amps, not powerful enough, ....... and the fact that it lacks power low frequencies do not stand out, all stax helmets are good, we can not say as much for their amps,
