Hersey is red -- a color of choice for us women. Those two implement very different technology but somehow sound very similar according to a reviewer. I am gong to grab a Hersey as soon as it becomes available in Europa. Amir @ ASR reviewed both and seems to prefer Hersey over 3+.
I got some angled sheepskin pads to try on my Sundara. They look very well made and came with the plastic ring attached. I took off one of the stock pads and that was the beginning of a very unpleasant experience. There was no way I could get the new pad to lock in place. The problem is the lack of any lateral movement in the Sundara driver. Very difficult to get a position so the driver is clear for the installation. The new pad is thick, much thicker than the stock pads. After an hour of attempting to install the new pad I gave up and replaced the original pad (which went on with a minimum of effort). The point here is the thick sheepskin pads are not worth the investment unless you have far better patience and skills than I have. If anyone here has succeeded at this I would love to know your secret. The farthest I could get with this was to latch 3 of the 4 tabs. That 4th tab just would not slip into a locked position no matter which tab I started with. Never even tried the second driver. No point in even attempting it unless I could latch the first one in place.
Did anyone else's Sundara come with a cosmetic defect? I just opened mine and noticed the paint is quite a bit chipped on one of the ear cups. I'm not sure if this is normal or if it's something worth complaining about and asking for a replacement?
Thanks but I viewed that video more than once. You will notice in the video they are using a Hifiman that has lateral movement in the ear cups so they can be laid flat for insertion. No such luck with the Sundara. That make it much harder but I think it is that fact combined with the thickness of the pads that complicates this application. Since my post I tried again and failed. I would note that the original pads which are much thinner come off and go back on with little difficulty. I think the very thick pads are just too much for the Sundara (or my skill level).
What I do is push the pad inwards with my thumbs on the outside of the ring, where tab is located until I hear the distinct click that signifies the tab is in place
Anyone got any recommendations for a closed back headphone to complement the sundara, looking for a different sound signature and currently considering one of the Fostex X00 variants
The Fostex TH xeries or the EMU Teak would be good closed-backs that are more "fun" sounding because of their V-shaped signature I would say. You could also consider the Elegia but they're tuned to be mid-forward from what I've read and probably pricier than the Fostex cans.
Can you please email us at customerservice@hifiman.com with the photos of your headphones so that we can look into what’s happened and to see how we can help?
Agreed on this, those Fostex/EMUs are great. I have an EMU with Ebony cups myself and they sound great. Something to bear in mind though, they’re not fully closed.
Doubt it. Based on their graphs, the 400i has a higher spike at 7k - 10k than the Sundara. From there, the Sundara is still bright-leaning, but is less forward with vocals and instruments in that same region.
Dekoni pads? I just changed out my Sundara pads a few weeks ago and it was indeed a PITA. No tips I'm afraid. I just kept at it and it took me around 10 minutes of fiddling around to get them on.
No these were some pads off ebay. They were a bit over $40. I returned them today. They look very well made but are too thick for Sundara. They probably work with HE models.
