MalinYamato
many Topping amps have high output impedance and those DX30 Pro and A50 do not seem to be good pairings with Sundaras. A50 : SE < 4.7Ω BAL < 9.4Ω DX30 Pro : SE < 10Ω
Model | Spec | Price * |
BTR5 | ES9218P * 2 240mW@32 BT | 120 |
Q5S + AM3D | AK4493EQ * 2 510mW@32 BT | 422 +202 |
Magni 3 Hersey | 2.4W@32Ω | 173 |
SMSL SP200 | 2x3W@32Ω 2x220mW@600Ω | 290 |
SMSL M200 | AK4497EQ, BT UAT | 290 |
SP200 + M200 | 526 | |
SMSL D500 | MQA, ES9038PR 570mW@32Ω, | 400 |
Topping A90 | 6.4W @32Ω 500mW@600Ω | 574 |
XD-05 Plus | AK4493EQ 1000mW@32Ω | 273 |
SE1DA 9038S | ES9038Q2M 340mW@32Ω | 121 |
Cable is cable dude. Don't waste money. Buy new cable if it gets broken.Hello friends,
I have just purchased my hifiman Sundara’s. Being totally new to this type of headphone (my other set is Grado SR80). Can anyone suggest a replacement cable instead of the cable that comes with the Sundara’s? Budget up to £50.00
Guys, what about amp?
Topping DX3 Pro?
Topping NX4S?
Topping A50?
Yes. Good picks. E30 and Heresy godlike performers with nice price. No need to go expensive unless you want balanced.Attach files
I recommend the Heresy, 2.4W for $99 USD is amazing!!! Modi 3 in black will look amazing as a stack, but I would recommend Topping E30 or SMSL Sanskrit 10th Mark II for their AK4493 chip. They also support DSD and higher bit depth/sample rate if that matters to you.
Hello friends,
If you aren't chasing after things such as occ, 7n, litz, etc. fancy wire material, Neomusica cable on Amazon is recommended for being more compact and lighter. For visual appealing + customization of length/termination then Hart cables + Periapt cables are highly recommend
Perhaps he wants custom length, ergonomics, termination for balanced etc.
More power also comes with price x I have Magni 3 and Asgard and prefer the asgard (But it is twice the price). And although I prefer the Asgard, the M3 is very good as well. Not trying to make your life more difficult, really!Yes. Good picks. E30 and Heresy godlike performers with nice price. No need to go expensive unless you want balanced.
Heresy power output similiar to Asgard 3. Magni 3 is old now.More power also comes with price x I have Magni 3 and Asgard and prefer the asgard (But it is twice the price). And although I prefer the Asgard, the M3 is very good as well. Not trying to make your life more difficult, really!
Magni 3+ good too. Heresy just measures better. More perfect product. Sound ? dunnoWhy not Magni 3+ instead of Heresy?
