Stealer
- Jun 7, 2011
How is the sound with this grill?
Where to get this..and what meterial is made of...
ThurstonX
thanks for the link...
do you mean that the one in the website will fit He560 without any mod?
Interested in getting a pair.
rgds
Also, if someone has a micometer and could measure the thickness of the original grills I'd be grateful.
No, it takes some work to mod the acrylic fan grills to get them to fit. I thought I posted the steps in this thread. Have a search (Advanced on my name). If not, I'm sure I PM'd the steps to someone, so PM me and I'll try to dig it up.
Briefly, you'll need to trim the fan mounts (I used a hacksaw; perfect tool), then carefully file them down until the grills slide in with enough friction to hold them in place. Carefully sanding (medium, then fine) the top sides is recommended, as they're unlikely to come through unscathed. The sanding makes it easier to spray paint. I used a flat black, which is what you see in the photos. Attaching a dust screen is a matter of taste, but I used spray adhesive to stick the organza fabric. It was a little hit and miss, so I touched up jexby's with a little glue stick paste strategically applied with a cotton swab.
HTH.
Can you quickly confirm the diameter you ordered from stock or did you order a custom diameter?
80 mm, then trimmed and filed the tabs for the screws.
I just found this thread and decided to give it a try. Popping off the outer ring is easy, just be careful and go slow. I removed just the cloth and put it back together. My initial impressions is that the treble was indeed cleaned up.
Regarding replacing the outer grill: wouldn't it be just as effective to drill several holes in the stock grill instead of replacing it? If the goal is to get more air moving in-and-out then that ought to do the trick just as well.
