DCofficehack
- Dec 27, 2009
If the 262 needs amping with faster, more complex music, does that mean that--unamped--it would not be ideal for big symphonies?
I am not a big listener of classical, so there's likely someone better to answer this... but I'll add a few comments.
I did some classical listening to get some impressions and I did like the overall presentation from the 262. The musical sound signature and overall soundstage suite me well for classical. However if I really want listen to the details, follow a particular instrument, or pick out the toe tapper in the seventh row of strings I'd likely choose another IEM.
I think ClieOS made a good point earlier in this post that fast complex music is not a strength for the 262, but I don't think anyone has said that it simply falls apart and is horrible. I wouldn't let these impressions scare you away from the 262 unless you feel that this type of music would make up the bulk of your listening. The 262 is capable (better when amped IMHO) but not spectacular.
If the bulk of your music is on the fast and complex side, if you're a detail type, perhaps you should consider an IEM with strengths in that area. That's not the bias of the more musical and smooth 262. The good news of course is that there are so many great affordable options out there to choose from.
I read somewhere that without an amp, the J3's battery life was reduced from 55 to 10 h.....
wow that is ridicoulous! do all iems suck up battery like this?
150 Ohm is quite unusual.....normally it would be around 16-32 Ohm.
iems are normally designed in such a way, that they can be driven by normal PMPs.
Yea just checked the stats again. It is 150 ohm. I think it has been designed to be used with bigger set ups as well
Well, it is from the same company that makes HM60x and HM801
