spurxiii
- May 18, 2013
The bass is not thick in the RE400s far from it IMO
First, thank you for sharing your experience detailed like that, It helped a lot to understand what it is all about nowadays. I have to say I haven't used an earphone that is above 100$ yet. Okay that this costs 100$ too, but it represents a higher quality, and you don't get a stuff like that for 100$ at the local plaza. The point is I don't know what to expect from these IEMs, because I have just a Sennheiser cx 400 II to compare with. But as you said clarity is one of the biggest virtue of this HiFiMan earphones so I don't have further worries. I hated added rumbling bass anyways at some earphones. If these stuff will provide clear bass, just the amount the creator of the music originally wanted I will be satisfied.
So my expectations are:
- clear music without any distortions
- it can reproduce wide range of sounds, but it is balanced
- high volume levels
- very high dynamics
From what you said, I think it will bring me all of the above.
I ordered a set of these today from the hifiman website (Head Direct). Hopefully, I will get them early next week. They will be supplementing/replacing my Monster Miles Davis Trumpets, which I like very much. But, my wife has hijacked them.:rolleyes:.
Last year I began looking for a set of iems to supplement/replace my Shure 840's which were, you guessed it, hijacked by my wife. . Back then, one of the iems I was researching was the hifiman re zeroamong others. I put that purchase off because I was gifted the Trumpets bymy kids. I like the iems better than over the ears mostly because of the comfort. I plan to use these with my Samsung s4 phone, no
amplifiying..
I think my only concern with these will be the in ear fit. The tips look real similar to some cheap ones that I have/tried that would not stay in my ears. Kept wanting to fall out. Hope these will fit better.
Frank
I have just got the Shure SE-215. RE-400 were bought blindly, and the character is just to lean/dry for me. For me Shure is different in a way that it suits me better. However I do use EQ (about -2/-3 db) for bass heavier music like Marley remasters. It works well, on the other hand lifting bass on RE-400 didn't work. It could also be that Shure tips are better for my ears. The only tip which can make a good seal on RE-400 are big double flanges. And the only thing I prefer on Hifimans is its form factor ... they are small and I could even sleep wearing them (if I could find more comfortable tips).
Anyone know how to wear the RE400s over the ears without it constantly falling off?
Sorry I meant to say the cable keeps falling off my ears. Maybe I need some ear guidesI am wearing them like that without problem. Seal with large biflange tips is so tight I sometimes strip the tips of the iems when pulling the out from ears.
Yes, SE215 are a bit to bassy for me also, but are easy to EQ.
Does anyone know any iems similar to SE215, with a bit less bass?
