Austin Morrow
Well, it has 20 ohms (ES5), which isn't a lot. I can't seem to find the output power for the HM-801 though. Anyone got a spec sheet?
Gee, did it ever occur to you that music you are listening to really does'nt have all that much resolution to begin with. I have a Touch & an HM-602 ,playing back wav files(which is by the way the reason to spend the money on these non-iPod players which do have inferior UIs.) the "Touch" can't touch the HM-602 in detail retreveal. Would it be fair to say you prefer the more foward sound of your Touch for the music you listen to? It's extremely inaccurate to call a higher priced player a ripoff. The player was'nt designed for people who think iPods sound pretty good, it was designed for people who don't really care for the way they sound ! The HiFiman players sound a little bit like decent analog sounds like ! I guess these players are for us old farts or at least anyone who has heard good analog (which as time goes by is rapidly declining).
the iPod Touch 3G has a more clearer and detailed sound that literally makes the HM-801 sound veiled and muddy in comparison. I know this is a perception caused by the treble roll off that the HM-801 has, but if it was so much superior I would still be hearing a more clearer and detailed sound than the iPod Touch 3G regardless of treble output.
Other DAP's play WAVE, you know!
Like for instance, my Cowon.
http://www.jetaudio.com/products/iaudio/7/
Not that any sane person should use WAVE.
I hear a slight difference between 320kbps and FLAC, but it's a difference that literally makes my head hurt to concentrate on to hear.
What!? If it doesn't sound better to " my " ears regardless of the audio codec used for the music over a FAR cheaper source than it's a rip off. Don't name the device " Hifiman " when " HiFi " stands for high fidelity or high accuracy. This thing is so far from accurate after reading those RMAA's and even hearing it with my own 2 ears. If this is what analog sounds like, count me out. I prefer digital. I want my source to be accurate and my headphones to color the sound.
I don't want to get involved in this conversation too much, but there is an inaccuracy here. RMAA isn't the last word in measuring "hifiness". Yes, there is a moderate roll-off in the higher frequencies on the Hifiman. But you can't deduct from that that it is any less "Hifi" than an iPod. I remember seeing on a Japanese website a measurement of the DAC impulse response. The Hifiman measured almost dead-on, the ipod terribly. So there is much more than just frequency response in level of Hifi accuracy.
Here's the link : http://sonove.angry.jp/apple_ipad.html
As you can see the HM 801 has a superb impulsion response measurement - many times better than any iDevice (which are a terrible mess at it). It has indeed an unfortunate roll off at high frequencies (remember however that 2,5 dB @ 15k hz isn't much - but the combination between your low impedance multi BA IEM and the HM 801 high output impedance - undeniably a mistake on Hifiman's part - might worsen the situation). Also, phase is quite well controlled in the high frequencies - the iPods have a pretty bad phase management up-there, that's likely to counteract any benefit of having 2,5 dB trebles more (I think if I'm correct that phase issues are bad for details). With these very bad impulse response and phase measurments, you cannot call the iDevices any more accuracte than the HM 801.
Also, in this comparison, it is important to distinguish between the DAC section and the amp section. For example, when I possessed them both, I directly compared an iPhone to a HM 602, but to level the playground I should have been using the same amp to determine which of the DAC is best.
It's also been noted several times by some people that the amp output impedance of the Hifiman isn't very good for multi BA drivers. Maybe should you try both the iPod and the HM 801 with an external amp to get a clearer view of each dac's abilities.
