riffrafff
TP for your bunghole?
"Are you threatening me?!?"
I can confirm it does fit the HE-4XX, as I have both. I used the Slappa case to carry my headphones, cable, and DAP without issue.
Has anyone used this case? According to the reviews it fits..
Slappa Full-Sized Duro-Shock xEVA HardBody Ballistic Nylon PRO Headphone Case with Ultimate Protection SL-HP-99
https://www.amazon.com/Slappa-Full-...8&qid=1536112994&sr=8-2&keywords=hifiman+case
This case fits my HE400i like a glove. A recommended case.
I’m sure they will work fine. Just make sure that your amp has the 2.5 TRRS balanced output. You can’t use those cables on normal single-ended output, like on a cell phone. You’ll need something like a FiiO Q1 Mark ii at least to drive the HE4XX’s. They need lots of amperage to drive them properly.
Received the cable today. They do not work. The headphones require a 3.5mm plug, this cable has a 2.5mm plug. Had to list them on ebay since I doubt it would be cheaper to send them back to China
If yours are 3.5mm then this is a recent change by Hifiman. My HE4XX’s are only a few months old and they have 2.5mm trs connectors at the earcups. See pics.
Yeah, I see what you mean. I don’t have a caliper on me, but yes they changed to 3.5mm at the cups.
Here is a pic of the stock cable. All 3 male ends are the same.
