JaZZ
It’s not uncommon to use and beef up the DAC’s analog output stage and use it like a pre and then connect the DAC direct to a power amp. The advantage to this is that you will have one amplifying stage and one connection less that the signal need to pass thru. The analog output stage of the DAC and the volume pot of course need to be of good quality, as good or better than a good pre.
This doesn’t mean that amplifying in different stages is bad and by doing it we automatically will introduce coloration. Most companies do want (for good reason) to separate the pre-amplifying from the power-amplifying stage which is separated from the DAC section. Sometimes they are placed in different boxes (shields + PSU) other times they are only separated by using individual PSU. Even Chord go separate in their more expansive gears.
The question is will the advantage of one less amplifying stage (it’s an advantage in my book) make it sound better with or without an additional amp? I think it depend on (1) how good the analog output stage in the DAC is compared to the amp xxx, (2) if the DAC has separate PSU’s for different tasks (digital, analog and left and right) (3) can the DAC deliver enough power/current/voltage to drive the HE1K at a certain loudness level, (4) does the DAC has a sound signature you like?
My 2c
A tiny logic error. Adding a preamp won't separate the DAC's output stage from its DAC section. So if the output stage (representing the preamp in the puristic configuration) is plagued by an interference from the DAC section, the signal sent to the preamp is also affected.
