musicinmymind
- Jan 31, 2012
I like stock Velour earpads more than Denon pads
I've always had this weird fetish dream you see.... a pair of headphones.... fed by a pair of monoblock speaker amps....
Baby steps... with monoblock headphone amps (which probably have enough juice for speakers anyways)
If by socket you mean the connectors, then no it is relatively easy. Just be careful and snip the wires before you unscrew it from the headphone or else you will will pull them off of the drivers which could potentially damage the driver. The wire leads soldered to the driver are solid core so they are quite stiff and brittle, treat them with care and you can solder your wires to them. Otherwise you will need to disassemble the driver from the cup to to get access to the solder joint at the driver, which is a PIA (I know because my right ground was snapped off at the joint and it took an hour or more to take the driver apart re-solder and reassemble).
Good luck
Ohh boy....I have never seen anyone connecting one HP to two amps. they are mono amps?
Yupp... that's how you swing her... gently.... but very determinately. In fact.. that's how you do anything in life
+1 to you Sir.
Has anyone tried the HE-6 out of the NFB 28 balanced. Will this be able to power the HE-6 to an acceptable volume (not talking about to earsplitting volume or its "maximum potential")
What do you guys think about a Concero or Bushmaster MKII dac for the HE-6 to go with my Bantam Gold as an upgrade for the ODAC?
There's also a few with dual mono amps like Dr. Roberts with a http://www.akkelisaudio.com/forstarkare/balanced-audio-technology-bat/bat-vk-55.htmlis
Best I've heard them on this http://www.simaudio.com/moon600i.htm
I run mine on http://www.audioreview.com/cat/amplification/amplifiers/rotel/rmb-100-mono/prd_116128_1583crx.aspx#reviews
