Armaegis
Modern Modder Man of Manitoba
HTML... uphill, both ways!
- Oct 18, 2009
I couldn't take it anymore! I yanked the ZEROs outta the system. Currently sitting inside the Tea room awaiting return shipping. Maybe Monday... Tuesday. Believe it or not, I had so much confidence the ZEROs would work out, I threw the box out the very first day.
These hockey pucks are a better match for my KEF Coda 9's, but I listen to the HE-6 most often times and I do not wanna surrender anymore current. Back to the HE-Adapter for now...
Originally Posted by Armaegis /img/forum/go_quote.gif
What was the config you were using again? Was it something like using the divide 4 taps into the 16 ohm speaker output?
You mentioned something about being unable to change the output on the amp (which seems odd to me). Is that still the case?
You aren't surrendering current with the autoformers. If anything, you're saving current since the adapter wastes current as heat.
Losing bass makes me feel like something is hooked up wrong, because if there's rolloff happening then there's some sort of weird interaction happening.
I was just wondering if these are any reasonably priced headphone amps that do work with the HE-6 or is it really only compatible with speaker amps. I have a Onkyo 150w/ch amp but that seems like it might be a bit too much.
Belles Soloist OCM-200 Power Amplifier
And a Rotel 970BX Power Amplifier
The only thing missing here is a preamp. Have any gut feelings as to what I should try them out with first?
Anyone hear about this amp? http://benchmarkmedia.com/pages/the-new-ahb2
Very excited to see the reviews for it. Probably snatch one up myself
You already have the "Krell KAV-400xi", why do you need one more?
Any idea what the cost of this amp is??
