Yup, doing so right now!
HifiMAN HE-6 Planar Magnetic Headphone
- Thread starter JIGF
Articnoise
Not Class D, but it has a switching power supply.No, but based on class D power and all the other "stuff" it has, I can't imagine it touching the AHB2 given the technology and design behind the AHB2.
“The AHB2 combines class-AB, and class-H topologies using a feed-forward error correction system.”
https://benchmarkmedia.com/products/benchmark-ahb2-power-amplifier
I was referring to his amp the Classe CA D200. I should have been more clear.
jarnopp
- Nov 26, 2014
I think the reason the Dekoni pads work so well is that the ear opening is perfectly circular like the stock pads. The diaphragm is also circular so it makes sense to avoid possible irregular reflections due to an irregular ear opening. One additional mod I did do was add two rings of adhesive felt around the very outside edge of the metal surrounding the driver and then a slightly bigger ring that covered that one and covered the plastic where the tabs snap in. I made four slots for the tabs to line up and go in. This has helped immensely with any reflections added by the plastic.
I just received the Elite Velour Dekoni's from this Massdrop:
https://www.massdrop.com/buy/dekoni-earpads-for-m50x-and-beyerdynamic-dt
My initial listening impressions are that they retain the soundstage and bass of the sheepskin, without the need for the felt mod. They reduce the treble glare from reflections, but without really being too dark (sibilant tracks like Cowboy Junkies' Sweet Jane are still sibilant). But cleaner sound overall results in a feeling of better balanc and more perceived bass.
Anyone else tried these with HE-6?
jarnopp
- Nov 26, 2014
One more thing, and I'm prepared for the rain of Schiit, the Hugo2 can drive the HE-6 directly and cleanly. Try before commenting; you will be around purple (line out), but it sounds very transparent.
Probably not going to happen unless someone has a Hugo 2 for me to try. I've upped my HE-6 amp game anyways.
bosiemoncrieff
I heard a little buzz using my panache speaker taps. I'll have to stick to the phones 1/4 inch jack from now on...
jarnopp
- Nov 26, 2014
Hi Bosie,
I'm only saying it's an option for maximum transparency and totally reasonable listening levels. I have the tour unit for the next 10 days if you want to try to meet in SF.
I have listened to HE-6 on Cavalli LC (like the sound of that amp), the Emotiva a100 and the Odyssey Stratos, so I think the 2 speaker amps were p,entry of good power. And, aside from the amp's individual tonality, the Hugo2 is more transparent and quite respectable, IMHO.
LarsHP
Which pads are you comparing them to?I just received the Elite Velour Dekoni's from this Massdrop:
jarnopp
- Nov 26, 2014
I should have stated that explicitly: the Dekoni sheepskin (regular, not fenestrated) that we had been discussing.
weasel1979
- Dec 23, 2016
Hi there, I am a new EF-6 owner. I do not own an HE-6. Currently I am using my Mr Speakers Ether C. I was wondering about the gain switch, what is the prefered position? Cheers
Rodeodave
- Jun 18, 2012
Generally speaking, it doesn't make sense to attenuate a signal only to then amplify it again. So this would point towards the lowest gain setting you can get away with.
Then again, you don't want to have an excessive input signal which may drive the last amplifying stage into clipping to reach a desired output signal. This would point towards a higher gain setting.
So, imo, if you can get away with the lower gain setting, use it.
Is there any apparent sonic difference to your ears?
geomaso44
- Jul 22, 2015
In case anybody would be interested in an unmodded Hifiman HE-6 in a very good condition (especially in Europe but can post pretty much everywhere), feel free to get in touch with me via PM - I am sure we can figure it out!
[I have a good feedback here but cannot post in Trade forum yet - need to work on this.]
bosiemoncrieff
That is a rare commodity. I'm sure it will be grabbed up quickly
Netherwind
Hi guys!
I got my HE-6 a few months back but never got around to posting in here.
I guess it's pretty unique (4 screw, black yokes).
Anyway, onto the good stuff...
I've been using Ori pads on the HE-6 since I got it, and just today received new pads from Zach.
Suede.
They are faaaaar more comfortable than stock velours (I have the originals with plastic rings).
They don't brighten the sound like stock Velours do. I'm still trying to figure out the bass aspect of them, seems to have less subbass than Ori which will turn some people off but they are so ridiculously comfortable and don't kill you with treble.
Suede.
Total: 19 (members: 0, guests: 19)
