wink
His amps are made out of recycled beer cans
and his source from tomatos.
- Apr 13, 2009
....eh....?
Yeah HE6 has a clamping force that's not pleasant. If they could reproduce their sound in an HEX/K body, I would buy that in an instant.
I have the stock velour pads—what's the difference between the focus pads and the focus pads-A?
For all the guys with comfort issues:
Vegan pads + hd600 headband + these ulgy as sin chinese hand woven headband raps = one of the most comfortable headphones I have ever worn.
How did you get the HD600 headband on the HE-6? Got any pics?
I agree. I have the Vegan pads + HD201 foam pad + Woolen wrap = Great comfort!
I think he means the HD 600 pad
http://www.custom-cable.co.uk/sennheiser-foam-headband-pad-for-hd600-hd580.html
Velours are awful for comfort. Arguably the worst pads ever in this regard. Focus pad and focus pad-A are far more comfortable. I think they sound a little bit better too. The focus pad generally has a little bit more emphasis in the upper mid range. That is the main difference between the two. Overall, the Audeze Vegan pads tend to be the preferred choice these days on this thread. So you may want to take a look at those as well.
While I find the Focus pads somewhat more comfortable I don't think the stock velours are 'awful'.
The old remedy for the scratchy stock velour is simply rinsing with a mild detergent (I used a wool wash - some say just plain warm water works).
I do think Focus pads are better finished and look far better on the headphones. Just wish I liked their sound.
*Warning, personal bias*
While many seem to favor the focus pads, I personally think they make the HE6 sound boring/uninteresting. This is either with or without the grill mod.
Call me crazy, but I preferred the HD600 to the HE6 with focus pads - which is definitely NOT the case with the stock velour on the HE6.
Audeze vegans are often put forward as 'end game' pads. However, I've read posts where listeners preferred the Focus pads.
All personal preference I guess.
Here are some measurements of different pads I've tried on the HE-6. This is with the HE-6 stock grills, fiber and foam.
