@duo8, Don't quite understand what you are asking?
It came like that, I bought it used.is this the dent that I circled?
Does it affect the sound? how did you get the dent?
sorry took so long to get back, my GF was getting hungry so I took a break to make dinner.It came like that, I bought it used.
It sounds mostly normal, though there seems to be clipping at certain frequencies/loudness combinations, though that could be equipment/source, since I noticed some clipping with my re400 as well.
Probably not, since this was the only one he had.sorry took so long to get back, my GF was getting hungry so I took a break to make dinner.
If you notice the clipping with your re400 as well I don't think the driver of the HE400i is damaged but if it bothers you can you return them to the seller saying they were defective?
I think the only way to get the drivers replace would be to send the entire headphone back to Hifiman and I have no idea what it would cost but if the dent doesn't affect the sound then I don't think I would go through the trouble and expense to send them back.Probably not, since this was the only one he had.
Ideally I'd be able to get a replacement driver for a reasonable price, but I doubt that.
Only you can decide if the pairing of your amp and the HE4XX sound good to you since we all hear differently. Another thing you might want to consider is how loud you listen at, your preferred genre of music and what type of sound signature do you like.Hi to everybody from Italy
New to head-fi and joined the he-4xx drop: 165 for cans and hybridpadA was a fantastic offer! And I like very much the idea of a drop that is a Christmas gift to myself
I got a little question about these cans: assuming them very similar to he-400i, I intend to use them with a portable Sabre dac/amp who can drive them at max 1,9Vrms and 2,7V peak to... it's ok to start with this system and in the future go ahead and upgrade the system or this dac/amp isn't capable to drive them enough well?
The 400i is not really that power hungry. At 93 db/mw and 35 ohms. They will give 110 DB with 50 milliwatts. Around 2.6 volts and 38 milliamps. It does not take a super powerful amp to do this. If you insist on listening at 120 DB (and killing your ears in the process), you can multiply that by around 10 !! The 02, theoretically, can do that as well.400i needs serious juice to sing, it sounds anemic out of a O2 for instance even at 6X gain.
anyway been doing some pad rolling, fact is that some rings break instantly while fitting oval brainwavz and others never give up so YMMV. Using my winning pair I'm currently listening to the angled pleather brainwavz, they sound distant due to their extreme thickness at the back and they're also quite sticky huh. My fav pair comfort-wise is the old hifiman velours because they're quite stiff which balances the weight against my skull quite nicely and they're not sticky to the least but deep bass is far from optimal. Stock hifiman pleather sound good and bass is great, aren't nearly quite as sticky as those oval pleather brainwavz but foam isn't stiff enough. Oh well, I see that the hifman pleather got a ring of rubber at the back, will try to stick it behind the hifiman velours then
