circlecrystal
- Nov 23, 2016
I'm also very happy with the way the LD I+ and the HE400i pairs up. Personally I find the possibility to roll tubes and op amps to be a great advantage (and very fun) but as always ymmv.
Personally I'd also be a bit concerned spending too much on a amplifier without a closed chassis. I've owned the Bravo V2, that also has an open design, for years and there's quite a bit of dust finding its way inside it and it's very hard to get it all removed.
For maybe 250 dollars you can get Elemental Watson, which I like a lot because of its cost-performance ratio with its price range (below 300 dollars). Probably the CP king given everything I have tried and compared below 300 dollars.
It's a duo mono design amp, which really helps channel isolation (reduce channel interference). The result is a much cleaner sound, instrument isolation, and larger soundstage than those without duo mono.
Then Watson also have the class A design, which helps the sound delivers a faster speed and cleaner sound.
http://www.head-fi.org/t/823002/elemental-watson-class-a-valve-mosfet-hybrid-headphone-amplifier-review-added
I have paired Elemental Watson with my previous HE400i, and it sounds quite impressive for its price --- though it did took around 100 hours to burn in.
