MattTCG
- Jan 22, 2012
wje...that's an impressive complement to the k167's bass quality. Would you mind saying a few things about the mids and treble?
thanks!!
thanks!!
how about the e10 would that work out alright?
also would you say the magi + modi is a noticeable jump up from e17
thanks!!
Since we've only seem the paper "specs" on the new Schiit gear, it is only speculation at this point. I believe some of the first deliveries of these new components will land in the hands of the owners this coming week. We'll then be able to get a better perspective on what kind of value vs. performance will be offered.
Given your push to spend money on headphones, yet fall within a certain price ceiling for an amplifier, I'd suggest that you might possibly consider some inner ear headphones first. They are cheaper, and are easier to drive. You could have your music desires met at a lower cost point. Then, as funds permit, move onto your desired headphones with sufficient amplification and DAC capabilities that will please you and not disappoint.
Darth, you may have the equivalent of a Asus Xonar card built in, if your MoBo is the "republic of gamers" edition that a quick google search revealed. There is also effort, in that case, to provide better than normal S/N and isolation of the audio stream.
Personally, I would get the phones first and try them with your onboard audio, which uses a very good TI OpAmp and can drive higher impedance headphones. In most cases, people need to take control of their audio settings in Windows, which, oft ignored, sound like crap on high end headphones by default. The main offense is usually DSP stuff that is great for cheap speakers, but needs to be shut off for hi-fi! Then, if you don't find it to your liking, I would get the Magni and save money on the DAC, which I doubt will make a world of difference in your sound.
If you don't have a DAC, i recommend both the modi and magni as a desktop/laptop pair. (But if you're on the move a lot with the laptop, i recommend the Fiio E17)
Without a standalone DAC, the sound from the realtek chip via 3.5mm to RCA on the magni will sound very distorted. So if you have a HE-400 in hand, buy the magni and hear it for yourself. The DAC makes worlds difference.
Indeed, i have the Asus Maximus V Formula mobo, which has all this "ROG" stuff on it. But if it's the equivalent of an asus xonar, im kinda impressed....
So i think i'll get the phones for now.
Cool. Make sure you get a stereo 3.5mm to RCA adapter should you spring for an external amp like the Schiit. For the O2, which I use, you would just need a 3.5mm male-male connector.
Also, make sure you connect the amp using your onboard audio's "line out" jack. Although I don't seem to have an issue using my headphone jack to make the connection to the amp, that is not best practice for feeding a signal to an amp.
Chances are, you will experience an awesome sound. What is left to decide is if you can hit adaquete volumes, and of course if there is something totally awful about the sound that calls for different hardware!
Ummmmmmm What?
First off, I use a similar realtek chipset. There is NO distortion from the line-outs, whether I use the HEADPHONE out (32 Ohm) or the Higher impedance line out (100 Ohm) to feed in the line-in of my O2. None. If there is a distorted output from a realtek chipset I haven't heard it yet.
Second-off, all onboard sound solutions are using a combination of DAC/amplification of lineouts. So, money doesn't necessarily need to be wasted on gear which might be worse, not better, than what he is already using.
Where is the line out jack? I'm assuming it's on the top, using an NZXT, as shown in these pictures: http://www.nzxt.com/new/products/crafted_series/phantom
How do i know? Picture tells a thousand words.
I own a $2500 rig. I'm pretty sure i know what im talking about.
LOL You caught me. Okay! They're not Hello Kitty. They're Razer Orca's that i spray painted red. I cut out the AKG Q701's 20FT Cable and put it on the Orca. Still is the crappiest for music i've ever heard of, but the most comfortable for gaming. (You can wear it for 10 hours straight).
