ilmothedude
- Dec 20, 2014
Pretty sure REV 3/4 are pretty non sibilant(on most recordings)
Is there any way to determine which revision I have because I haven't found my HE-400 sibilant pretty much at all.
They're actually most easy sounding phones I have listened to and I can listen them with higher volumes than any other phones.
Best pads for comfort that I tried are SHR-1840 pads, had a spare set that came with the SRH-1840,
very comfortable but because it brought the driver closer to my ears the highs got a little harsh.
I use SRH-1440 pads which are presumably identical, and they are definitely very comfortable.
I didn't notice any harshness is highs but I still did raise pads a bit with foam to keep soundstage wide.
You could try same method if that would help with your highs.
