MattTCG
- Jan 22, 2012
^^ It has almost nothing to do with tube vs ss and mostly to do with the experience offered by the amp.
i wish i was in the community when it happened... you have to imagine the shock when the forum troll designs a better amp than the professionals...
also, if i order an o2 amp, it should come with a cable to connect to my dac with, right?
Where can I find a link to download the posihfopit version? The site hosting the software is down.
I forgot. I got mine through JDS labs (they were great). You need to buy a power adapter. You can get the standard wall wart ($11), or buy one from Mouser or wherever that is in spec. So, you are up to $141+shipping.
You will also need a cable for connection to your DAC. Based on what you have, a Y-Splitter / 3.5mm adapter. Saw some in Target the other day for about 6 bucks. Probably some "1 penny" deals out there (like monoprice or amazon).
I bought a very short 3.5mm to 3.5mm for the ODAC (3 inches!), but wish I had gone a little longer (cable lifts the ODAC in the air lol). The ODAC comes with a nice long USB cable should you decide you want it.
A big reason I bought the O2 had nothing to do with the "controversy" per-se and everything to do with the fact that actual published specs on the thing were available to look at! It is an open source design, so it is making money for a few small companies. It has also "raised the bar" in some ways on what a "cheap" amp should be able to do. I was horrified when I started looking for headphone amps at the lack of information and impossible-to-determine quality. The marketing / fact ratios are way off.
The Schiit amp came out after I bought the O2, so as far as good cheap amps go, there are mainly that one, the O2, and Fiio amps. Gain figures, output impedance, and power output are critical specs that many companies don't publish. So, automatic pass on those products unless I can find out somehow. What? You'd buy a car without knowing the gas mileage and horsepower? I think not!
looks like amazon's comes with power adapter http://www.amazon.com/gp/product/B00E0DMCO0/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1
for Y-Splitter / 3.5mm adapter, i assume you mean with 2 male and 1 female, you need a female for the amp, right?
Hello ppl, I was getting a bit irritated with the HE400 due to the usual issues, sibilance, recessed upper mids, harsh / artificial treble sound..... I think I finally cracked it, Making these good all rounders.... Obviously they still excel at some genres and not so great with others but at least I actually enjoy using these with vocals, metal, rock etc. now, they were always good with electronic, OST etc. Here is what I did.....
1) EQ with electri-Q - (Bass boost, slight boost from 600hz down, leave 700-1500 flat as they are raised anyway, about a 3 DB boost from ~1800-6000hz, 2 dips at ~7500hz and ~12500hz) You might have already done that.... But here is the little secret I found to make the treble sound more natural, really helps the "tizz" etc....
2) Using Elelctri-Q (in digital mode) set all the points above 6khz to "warm - peak analog filter" (leaving everything else on "peak-orfandis") this seems to add an analog type effect to the upper treble which gives slightly more decay and smoother / more natural treble, because lets face it the stock treble on these does not sound natural.... But with the EQ and the filters on the treble... Much better, I am actually enjoying metal on these now which before all I used them for was electronic and OST. You still get the clarity from 0-6000hz but the treble sounds smoother / slightly blurred / more decay, no more ear pain or sibilance and a more natural decay on the treble...
I gave point 2 a try, and im A/Bing between with and without the warm filter and honestly I'm not hearing a difference. Is it subtle or noticeable for you?
No I put the HE400 for sale but nobody bought them.
Tough times for dissatisfied HE-400 owners. There's so many up for sale on the classifieds and Hifiman just lowered the price of them.
