My R6 pro (chinese firmware 1.1) came in last night as well. I have not had the chance to use the R6 or R3 prior to this unit.
Reading about some of the issues which plagued the R6, the R6 pro doesn't seem to have the wifi issues that its predecessor had.
Sound quality on standard output certainly is already good, i wonder how 4.4 balanced will sound like (my cables are coming in later this month)
I had to reset my device on multiple occasions yesterday night as a result of trying to install Google Playstore
Installing the APK for the google apps resulted in a never ending crash for Google Framework --> Reset
Using the old method of installing the google apps via zip using the manual update resulted it being stuck on Hiby loading screen ---> Reset
Installing just the google play store apk was okay, opening it caused it to force close ---> Uninstall
Youtube app (via apk install) could not work as well as it relied upon google services to work ---> Uninstall
Spotify app (via apk install) worked
Upon contacting the Hiby team on FB, they confirmed that there wasn't any compatible google framework with the current china units on the chinese firmware. When quizzed upon when a release would be coming for this issue, they did not respond.
