@Joe Bloggs : Maybe you can pass on this error listing to the Hiby Developers to help solve the Trust anchor problem?
2020-12-07 11:14:28.825 7890-7942/? D/FotaUpdate: [ReportManager.java:359] run -> javax.net.ssl.SSLHandshakeException: java.security.cert.CertPathValidatorException: Trust anchor for certification path not found.
2020-12-07 11:14:28.826 7890-7942/? W/System.err: javax.net.ssl.SSLHandshakeException: java.security.cert.CertPathValidatorException: Trust anchor for certification path not found.
2020-12-07 11:14:28.826 7890-7942/? W/System.err: at com.android.org.conscrypt.ConscryptFileDescriptorSocket.startHandshake(ConscryptFileDescriptorSocket.java:219)
2020-12-07 11:14:28.826 7890-7942/? W/System.err: at com.squareup.okhttp.internal.io.RealConnection.connectTls(RealConnection.java:192)
2020-12-07 11:14:28.826 7890-7942/? W/System.err: at com.squareup.okhttp.internal.io.RealConnection.connectSocket(RealConnection.java:149)
2020-12-07 11:14:28.826 7890-7942/? W/System.err: at com.squareup.okhttp.internal.io.RealConnection.connect(RealConnection.java:112)
2020-12-07 11:14:28.826 7890-7942/? W/System.err: at com.squareup.okhttp.internal.http.StreamAllocation.findConnection(StreamAllocation.java:184)
2020-12-07 11:14:28.826 7890-7942/? W/System.err: at com.squareup.okhttp.internal.http.StreamAllocation.findHealthyConnection(StreamAllocation.java:126)
2020-12-07 11:14:28.826 7890-7942/? W/System.err: at com.squareup.okhttp.internal.http.StreamAllocation.newStream(StreamAllocation.java:95)
2020-12-07 11:14:28.826 7890-7942/? W/System.err: at com.squareup.okhttp.internal.http.HttpEngine.connect(HttpEngine.java:281)
2020-12-07 11:14:28.826 7890-7942/? W/System.err: at com.squareup.okhttp.internal.http.HttpEngine.sendRequest(HttpEngine.java:224)
2020-12-07 11:14:28.826 7890-7942/? W/System.err: at com.squareup.okhttp.Call.getResponse(Call.java:286)
2020-12-07 11:14:28.826 7890-7942/? W/System.err: at com.squareup.okhttp.Call$ApplicationInterceptorChain.proceed(Call.java:243)
2020-12-07 11:14:28.826 7890-7942/? W/System.err: at com.squareup.okhttp.Call.getResponseWithInterceptorChain(Call.java:205)
2020-12-07 11:14:28.826 7890-7942/? W/System.err: at com.squareup.okhttp.Call.execute(Call.java:80)
2020-12-07 11:14:28.826 7890-7942/? W/System.err: at com.adups.fota.utils.p.a(OkHttpUtil.java:108)
2020-12-07 11:14:28.826 7890-7942/? W/System.err: at com.adups.fota.update.d.b$3.run(ReportManager.java:331)
2020-12-07 11:14:28.827 7890-7942/? W/System.err: at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1162)
2020-12-07 11:14:28.827 7890-7942/? W/System.err: at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:636)
2020-12-07 11:14:28.827 7890-7942/? W/System.err: at java.lang.Thread.run(Thread.java:764)
2020-12-07 11:14:28.827 7890-7942/? W/System.err: Caused by: java.security.cert.CertificateException: java.security.cert.CertPathValidatorException: Trust anchor for certification path not found.
2020-12-07 11:14:28.827 7890-7942/? W/System.err: at com.android.org.conscrypt.TrustManagerImpl.verifyChain(TrustManagerImpl.java:661)
2020-12-07 11:14:28.827 7890-7942/? W/System.err: at com.android.org.conscrypt.TrustManagerImpl.checkTrustedRecursive(TrustManagerImpl.java:539)
2020-12-07 11:14:28.827 7890-7942/? W/System.err: at com.android.org.conscrypt.TrustManagerImpl.checkTrusted(TrustManagerImpl.java:495)
2020-12-07 11:14:28.827 7890-7942/? W/System.err: at com.android.org.conscrypt.TrustManagerImpl.checkTrusted(TrustManagerImpl.java:418)
2020-12-07 11:14:28.827 7890-7942/? W/System.err: at com.android.org.conscrypt.TrustManagerImpl.getTrustedChainForServer(TrustManagerImpl.java:339)
2020-12-07 11:14:28.827 7890-7942/? W/System.err: at android.security.net.config.NetworkSecurityTrustManager.checkServerTrusted(NetworkSecurityTrustManager.java:94)
2020-12-07 11:14:28.827 7890-7942/? W/System.err: at android.security.net.config.RootTrustManager.checkServerTrusted(RootTrustManager.java:88)
2020-12-07 11:14:28.827 7890-7942/? W/System.err: at com.android.org.conscrypt.Platform.checkServerTrusted(Platform.java:197)
2020-12-07 11:14:28.827 7890-7942/? W/System.err: at com.android.org.conscrypt.ConscryptFileDescriptorSocket.verifyCertificateChain(ConscryptFileDescriptorSocket.java:399)
2020-12-07 11:14:28.827 7890-7942/? W/System.err: at com.android.org.conscrypt.NativeCrypto.SSL_do_handshake(Native Method)
2020-12-07 11:14:28.827 7890-7942/? W/System.err: at com.android.org.conscrypt.SslWrapper.doHandshake(SslWrapper.java:374)
2020-12-07 11:14:28.827 7890-7942/? W/System.err: at com.android.org.conscrypt.ConscryptFileDescriptorSocket.startHandshake(ConscryptFileDescriptorSocket.java:217)
2020-12-07 11:14:28.827 7890-7942/? W/System.err: ... 17 more
2020-12-07 11:14:28.828 7890-7942/? W/System.err: Caused by: java.security.cert.CertPathValidatorException: Trust anchor for certification path not found.
2020-12-07 11:14:28.828 7890-7942/? W/System.err: ... 29 more
2020-12-07 11:14:28.828 7890-7942/? D/FotaUpdate: [ReportManager.java:103] run -> insert data to db, type = check; result = {"action":"check","data":{"apn":-2,"check_type":2,"errCode":"3008","reason":"java.security.cert.CertPathValidatorException: Trust anchor for certification path not found.","status":2,"time":"1607357668076","type":1,"version":""}}
2020-12-07 11:14:28.849 7890-7942/? D/FotaUpdate: [ReportManager.java:363] a -> type = check; content = {"action":"check","data":{"apn":-2,"check_type":2,"errCode":"3008","reason":"java.security.cert.CertPathValidatorException: Trust anchor for certification path not found.","status":2,"time":"1607357668076","type":1,"version":""}}
2020-12-07 11:14:28.850 1095-1357/? D/CompatibilityInfo: mCompatibilityFlags - 0
2020-12-07 11:14:28.850 1095-1357/? D/CompatibilityInfo: applicationDensity - 320
2020-12-07 11:14:28.850 1095-1357/? D/CompatibilityInfo: applicationScale - 1.0
2020-12-07 11:14:28.854 7890-9678/? D/FotaUpdate: [ReportIntentService.java:32] onHandleIntent -> isConnected = true
2020-12-07 11:14:28.855 7890-9678/? D/FotaUpdate: [DownReport.java:325] c -> isExists = false
2020-12-07 11:14:28.857 7890-9678/? D/FotaUpdate: [QuerySelfUpdate.java:54] a -> not arrive report self update data schedule!
2020-12-07 11:14:28.858 7890-7942/? D/FotaUpdate: [ReportManager.java:123] b -> record items size= 26
2020-12-07 11:14:28.866 7890-7942/? D/FotaUpdate: [Mid.java:40] a -> getSyncMid, mid = 20200512092806Ex5192 sd_mid = 20200512092806Ex5192
2020-12-07 11:14:28.884 7890-7942/? W/System.err: java.lang.reflect.InvocationTargetException
2020-12-07 11:14:28.884 7890-7942/? W/System.err: at java.lang.reflect.Method.invoke(Native Method)
2020-12-07 11:14:28.885 7890-7942/? W/System.err: at com.a.a.a.b.d(SimCardsManager.java:649)
2020-12-07 11:14:28.885 7890-7942/? W/System.err: at com.a.a.a.b.a(SimCardsManager.java:56)
2020-12-07 11:14:28.885 7890-7942/? W/System.err: at com.adups.fota.utils.d.<init>(DeviceInfoProvider.java:44)
2020-12-07 11:14:28.885 7890-7942/? W/System.err: at com.adups.fota.utils.d.a(DeviceInfoProvider.java:64)
2020-12-07 11:14:28.885 7890-7942/? W/System.err: at com.adups.fota.update.d.b.b(ReportManager.java:137)
2020-12-07 11:14:28.885 7890-7942/? W/System.err: at com.adups.fota.update.d.b$1.run(ReportManager.java:94)
2020-12-07 11:14:28.885 7890-7942/? W/System.err: at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1162)
2020-12-07 11:14:28.885 7890-7942/? W/System.err: at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:636)
2020-12-07 11:14:28.885 7890-7942/? W/System.err: at java.lang.Thread.run(Thread.java:764)
2020-12-07 11:14:28.886 7890-7942/? W/System.err: Caused by: java.lang.SecurityException: getImeiForSlot: Neither user 10042 nor current process has android.permission.READ_PHONE_STATE.
2020-12-07 11:14:28.886 7890-7942/? W/System.err: at android.os.Parcel.readException(Parcel.java:2004)
2020-12-07 11:14:28.886 7890-7942/? W/System.err: at android.os.Parcel.readException(Parcel.java:1950)
2020-12-07 11:14:28.886 7890-7942/? W/System.err: at com.android.internal.telephony.ITelephony$Stub$Proxy.getImeiForSlot(ITelephony.java:4975)
2020-12-07 11:14:28.886 7890-7942/? W/System.err: at android.telephony.TelephonyManager.getImei(TelephonyManager.java:1076)
2020-12-07 11:14:28.886 7890-7942/? W/System.err: ... 10 more
2020-12-07 11:14:28.912 7890-7942/? W/System.err: java.io.FileNotFoundException: /sys/class/net/eth0/address (No such file or directory)
2020-12-07 11:14:28.913 7890-7942/? W/System.err: at java.io.FileInputStream.open0(Native Method)
2020-12-07 11:14:28.913 7890-7942/? W/System.err: at java.io.FileInputStream.open(FileInputStream.java:200)
2020-12-07 11:14:28.913 7890-7942/? W/System.err: at java.io.FileInputStream.<init>(FileInputStream.java:150)
2020-12-07 11:14:28.913 7890-7942/? W/System.err: at java.io.FileInputStream.<init>(FileInputStream.java:103)
2020-12-07 11:14:28.914 7890-7942/? W/System.err: at java.io.FileReader.<init>(FileReader.java:58)
2020-12-07 11:14:28.914 7890-7942/? W/System.err: at com.adups.fota.utils.d.a(DeviceInfoProvider.java:420)
2020-12-07 11:14:28.914 7890-7942/? W/System.err: at com.adups.fota.utils.d.g(DeviceInfoProvider.java:376)
2020-12-07 11:14:28.914 7890-7942/? W/System.err: at com.adups.fota.utils.d.g(DeviceInfoProvider.java:338)
2020-12-07 11:14:28.914 7890-7942/? W/System.err: at com.adups.fota.utils.d.d(DeviceInfoProvider.java:117)
2020-12-07 11:14:28.914 7890-7942/? W/System.err: at com.adups.fota.update.d.b.b(ReportManager.java:137)
2020-12-07 11:14:28.914 7890-7942/? W/System.err: at com.adups.fota.update.d.b$1.run(ReportManager.java:94)
2020-12-07 11:14:28.914 7890-7942/? W/System.err: at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1162)
2020-12-07 11:14:28.914 7890-7942/? W/System.err: at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:636)
2020-12-07 11:14:28.914 7890-7942/? W/System.err: at java.lang.Thread.run(Thread.java:764)
2020-12-07 11:14:28.960 7890-7942/? W/System.err: java.lang.reflect.InvocationTargetException
2020-12-07 11:14:28.960 7890-7942/? W/System.err: at java.lang.reflect.Method.invoke(Native Method)
2020-12-07 11:14:28.960 7890-7942/? W/System.err: at com.a.a.a.b.d(SimCardsManager.java:649)
2020-12-07 11:14:28.960 7890-7942/? W/System.err: at com.a.a.a.b.a(SimCardsManager.java:56)
2020-12-07 11:14:28.960 7890-7942/? W/System.err: at com.adups.fota.utils.d.<init>(DeviceInfoProvider.java:44)
2020-12-07 11:14:28.960 7890-7942/? W/System.err: at com.adups.fota.utils.d.a(DeviceInfoProvider.java:64)
2020-12-07 11:14:28.960 7890-7942/? W/System.err: at com.adups.fota.update.d.b.b(ReportManager.java:139)
2020-12-07 11:14:28.960 7890-7942/? W/System.err: at com.adups.fota.update.d.b$1.run(ReportManager.java:94)
2020-12-07 11:14:28.960 7890-7942/? W/System.err: at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1162)
2020-12-07 11:14:28.960 7890-7942/? W/System.err: at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:636)
2020-12-07 11:14:28.960 7890-7942/? W/System.err: at java.lang.Thread.run(Thread.java:764)
2020-12-07 11:14:28.960 7890-7942/? W/System.err: Caused by: java.lang.SecurityException: getImeiForSlot: Neither user 10042 nor current process has android.permission.READ_PHONE_STATE.
2020-12-07 11:14:28.961 7890-7942/? W/System.err: at android.os.Parcel.readException(Parcel.java:2004)
2020-12-07 11:14:28.961 7890-7942/? W/System.err: at android.os.Parcel.readException(Parcel.java:1950)
2020-12-07 11:14:28.961 7890-7942/? W/System.err: at com.android.internal.telephony.ITelephony$Stub$Proxy.getImeiForSlot(ITelephony.java:4975)
2020-12-07 11:14:28.961 7890-7942/? W/System.err: at android.telephony.TelephonyManager.getImei(TelephonyManager.java:1076)
2020-12-07 11:14:28.961 7890-7942/? W/System.err: ... 10 more
2020-12-07 11:14:28.978 7890-7942/? W/System.err: java.lang.reflect.InvocationTargetException
2020-12-07 11:14:28.978 7890-7942/? W/System.err: at java.lang.reflect.Method.invoke(Native Method)
2020-12-07 11:14:28.978 7890-7942/? W/System.err: at com.a.a.a.b.d(SimCardsManager.java:649)
2020-12-07 11:14:28.978 7890-7942/? W/System.err: at com.a.a.a.b.a(SimCardsManager.java:56)
2020-12-07 11:14:28.978 7890-7942/? W/System.err: at com.adups.fota.utils.d.<init>(DeviceInfoProvider.java:44)
2020-12-07 11:14:28.978 7890-7942/? W/System.err: at com.adups.fota.utils.d.a(DeviceInfoProvider.java:64)
2020-12-07 11:14:28.978 7890-7942/? W/System.err: at com.adups.fota.update.d.b.b(ReportManager.java:140)
2020-12-07 11:14:28.978 7890-7942/? W/System.err: at com.adups.fota.update.d.b$1.run(ReportManager.java:94)
2020-12-07 11:14:28.978 7890-7942/? W/System.err: at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1162)
2020-12-07 11:14:28.978 7890-7942/? W/System.err: at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:636)
2020-12-07 11:14:28.978 7890-7942/? W/System.err: at java.lang.Thread.run(Thread.java:764)
2020-12-07 11:14:28.978 7890-7942/? W/System.err: Caused by: java.lang.SecurityException: getImeiForSlot: Neither user 10042 nor current process has android.permission.READ_PHONE_STATE.
2020-12-07 11:14:28.978 7890-7942/? W/System.err: at android.os.Parcel.readException(Parcel.java:2004)
2020-12-07 11:14:28.978 7890-7942/? W/System.err: at android.os.Parcel.readException(Parcel.java:1950)
2020-12-07 11:14:28.978 7890-7942/? W/System.err: at com.android.internal.telephony.ITelephony$Stub$Proxy.getImeiForSlot(ITelephony.java:4975)
2020-12-07 11:14:28.978 7890-7942/? W/System.err: at android.telephony.TelephonyManager.getImei(TelephonyManager.java:1076)
2020-12-07 11:14:28.978 7890-7942/? W/System.err: ... 10 more
2020-12-07 11:14:28.988 7890-7942/? D/FotaUpdate: [ReportManager.java:186] b -> http URL =
https://fota5s.adups.com/otainter-5.0/fota5/submitReport.do
2020-12-07 11:14:29.403 7890-7942/? D/FotaUpdate: [ReportManager.java:202] b -> javax.net.ssl.SSLHandshakeException: java.security.cert.CertPathValidatorException: Trust anchor for certification path not found.
2020-12-07 11:14:29.403 7890-7942/? W/System.err: javax.net.ssl.SSLHandshakeException: java.security.cert.CertPathValidatorException: Trust anchor for certification path not found.
2020-12-07 11:14:29.403 7890-7942/? W/System.err: at com.android.org.conscrypt.ConscryptFileDescriptorSocket.startHandshake(ConscryptFileDescriptorSocket.java:219)
2020-12-07 11:14:29.404 7890-7942/? W/System.err: at com.squareup.okhttp.internal.io.RealConnection.connectTls(RealConnection.java:192)
2020-12-07 11:14:29.404 7890-7942/? W/System.err: at com.squareup.okhttp.internal.io.RealConnection.connectSocket(RealConnection.java:149)
2020-12-07 11:14:29.404 7890-7942/? W/System.err: at com.squareup.okhttp.internal.io.RealConnection.connect(RealConnection.java:112)
2020-12-07 11:14:29.404 7890-7942/? W/System.err: at com.squareup.okhttp.internal.http.StreamAllocation.findConnection(StreamAllocation.java:184)
2020-12-07 11:14:29.404 7890-7942/? W/System.err: at com.squareup.okhttp.internal.http.StreamAllocation.findHealthyConnection(StreamAllocation.java:126)
2020-12-07 11:14:29.404 7890-7942/? W/System.err: at com.squareup.okhttp.internal.http.StreamAllocation.newStream(StreamAllocation.java:95)
2020-12-07 11:14:29.404 7890-7942/? W/System.err: at com.squareup.okhttp.internal.http.HttpEngine.connect(HttpEngine.java:281)
2020-12-07 11:14:29.404 7890-7942/? W/System.err: at com.squareup.okhttp.internal.http.HttpEngine.sendRequest(HttpEngine.java:224)
2020-12-07 11:14:29.404 7890-7942/? W/System.err: at com.squareup.okhttp.Call.getResponse(Call.java:286)
2020-12-07 11:14:29.404 7890-7942/? W/System.err: at com.squareup.okhttp.Call$ApplicationInterceptorChain.proceed(Call.java:243)
2020-12-07 11:14:29.404 7890-7942/? W/System.err: at com.squareup.okhttp.Call.getResponseWithInterceptorChain(Call.java:205)
2020-12-07 11:14:29.404 7890-7942/? W/System.err: at com.squareup.okhttp.Call.execute(Call.java:80)
2020-12-07 11:14:29.404 7890-7942/? W/System.err: at com.adups.fota.utils.p.a(OkHttpUtil.java:108)
2020-12-07 11:14:29.404 7890-7942/? W/System.err: at com.adups.fota.update.d.b.b(ReportManager.java:187)
2020-12-07 11:14:29.404 7890-7942/? W/System.err: at com.adups.fota.update.d.b$1.run(ReportManager.java:94)
2020-12-07 11:14:29.404 7890-7942/? W/System.err: at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1162)
2020-12-07 11:14:29.404 7890-7942/? W/System.err: at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:636)
2020-12-07 11:14:29.404 7890-7942/? W/System.err: at java.lang.Thread.run(Thread.java:764)
2020-12-07 11:14:29.405 7890-7942/? W/System.err: Caused by: java.security.cert.CertificateException: java.security.cert.CertPathValidatorException: Trust anchor for certification path not found.
2020-12-07 11:14:29.405 7890-7942/? W/System.err: at com.android.org.conscrypt.TrustManagerImpl.verifyChain(TrustManagerImpl.java:661)
2020-12-07 11:14:29.405 7890-7942/? W/System.err: at com.android.org.conscrypt.TrustManagerImpl.checkTrustedRecursive(TrustManagerImpl.java:539)
2020-12-07 11:14:29.405 7890-7942/? W/System.err: at com.android.org.conscrypt.TrustManagerImpl.checkTrusted(TrustManagerImpl.java:495)
2020-12-07 11:14:29.405 7890-7942/? W/System.err: at com.android.org.conscrypt.TrustManagerImpl.checkTrusted(TrustManagerImpl.java:418)
2020-12-07 11:14:29.405 7890-7942/? W/System.err: at com.android.org.conscrypt.TrustManagerImpl.getTrustedChainForServer(TrustManagerImpl.java:339)
2020-12-07 11:14:29.405 7890-7942/? W/System.err: at android.security.net.config.NetworkSecurityTrustManager.checkServerTrusted(NetworkSecurityTrustManager.java:94)
2020-12-07 11:14:29.405 7890-7942/? W/System.err: at android.security.net.config.RootTrustManager.checkServerTrusted(RootTrustManager.java:88)
2020-12-07 11:14:29.405 7890-7942/? W/System.err: at com.android.org.conscrypt.Platform.checkServerTrusted(Platform.java:197)
2020-12-07 11:14:29.405 7890-7942/? W/System.err: at com.android.org.conscrypt.ConscryptFileDescriptorSocket.verifyCertificateChain(ConscryptFileDescriptorSocket.java:399)
2020-12-07 11:14:29.405 7890-7942/? W/System.err: at com.android.org.conscrypt.NativeCrypto.SSL_do_handshake(Native Method)
2020-12-07 11:14:29.405 7890-7942/? W/System.err: at com.android.org.conscrypt.SslWrapper.doHandshake(SslWrapper.java:374)
2020-12-07 11:14:29.405 7890-7942/? W/System.err: at com.android.org.conscrypt.ConscryptFileDescriptorSocket.startHandshake(ConscryptFileDescriptorSocket.java:217)
2020-12-07 11:14:29.405 7890-7942/? W/System.err: ... 18 more
2020-12-07 11:14:29.405 7890-7942/? W/System.err: Caused by: java.security.cert.CertPathValidatorException: Trust anchor for certification path not found.
